Won't turn over
   / Won't turn over #1
Rustywreck
Solon Springs, Wisconsin
New Holland T 1520
I used my T1520 today (hst). I shut it off, tried to start it right after shutting it off and nothing. The dash lights come on, but no sounds coming from the starter - kinda like if I tried to start it in gear, just nothing.
Also, when using it earlier I noticed the PTO light on the dash was on. I looked and the shaft was not spinning. I engaged the PTO lever and the PTO spun; disengaged and the shaft stopped but the dash light remained on.
I don't know if the PTO light and it not starting are connected. Any suggestions on where to start first?
Oh, if I leave the ignition on and get off the seat it beeps, so it likely isn't the seat kill switch.
   / Won't turn over #2
Take a look under the left side operators platform for a pair of wires going into the tranny. My 33D has two wire under there that sense PTO position and when disconnected indicate the PTO is engaged. I put some wire loom around them and haven't had any brush pull them free since.
   / Won't turn over #3
Do a search for "#2 fuse", lots to read. Not sure which fuse for a T1520, but you'll get the idea.
   / Won't turn over
wasn't a fuse. there was a wire underneath that was unplugged. don't know how it happened, unless it was my stinkin' chickens - they like messing around under the tractor.
thanks for the advice.
   / Won't turn over #5
Just don't let the chickens around the key, who knows what havoc they may raise!
   / Won't turn over #7
When I turn the key, all I get is a clucking noise!:laughing::laughing::laughing:
Sir:
A good pun may be admitted among the smaller excellencies of lively conversation.
Your most obedient and humble servant,
James Boswell
1273 (A50490)
1273 (A50490)
2010 LOAD MAX 40 FOOT GOOSENECK (A53843)
2010 LOAD MAX 40...
2025 25ft. 800Amp Extra HD Booster Cables (A51692)
2025 25ft. 800Amp...
2015 Ford Taurus AWD Sedan (A51694)
2015 Ford Taurus...
grapple for mini skid steer (A53421)
grapple for mini...
2001 CATERPILLAR 140H VHP MOTORGRADER (A51406)
2001 CATERPILLAR...
