Standard L series owners POST YOUR SMOOTH 3PT HITCH VIDS HERE
   / Standard L series owners POST YOUR SMOOTH 3PT HITCH VIDS HERE #1
jokergerm
Gold Member
Ok, since people say that they have the standard L-Series tractors from the factory with a smooth 3pt hitch, i am calling you out. I want to see anyone with a smooth 3 point hitch like mine is now to post a video to prove it to us. Even if you are a dealer, STAND BEHIND YOUR PRODUCT AND PROVE ME WRONG.
This is all for the cause of FIXING this issue. No to make anyone look bad. Please help the others that are stuck with this BS. Also this thread was started by me at the request of other members
So if anyone can do this ( see link below) POST THE DAM VIDEO
Hitch - YouTube
Second clip is with auger
http://www.youtube.com/watch?v=sPUnz3SmOgQ&NR=1
its mighty lonley in here..............
   / Standard L series owners POST YOUR SMOOTH 3PT HITCH VIDS HERE #3
I can't post a video because I have a JERKY 3ph on my L4400
   / Standard L series owners POST YOUR SMOOTH 3PT HITCH VIDS HERE #4
Are you a betting man? Cause I am betting you will not get a single one.
I could be wrong, and have been before, but I doubt it.
   / Standard L series owners POST YOUR SMOOTH 3PT HITCH VIDS HERE #5
He can get all the videos he wants. But they'll all be of his tractor.
   / Standard L series owners POST YOUR SMOOTH 3PT HITCH VIDS HERE #6
I have a Kubota L3000 DT and it has a jerky 3 point hitch, I do you fix it? May 2011 007.jpg
   / Standard L series owners POST YOUR SMOOTH 3PT HITCH VIDS HERE #7
ugh...
this is drives me nuts because its such a subjective thing. The L4400 uses the same 3pt as the entire grand L10 and L30 series did. If you infact have a jerky 3pt, its probably sucking air somewhere and has an actual mechanical problem that should be looked at.
I'll do a video and post it on our website somtime. I'll line up 5-6 of them at the same time. I just got back from vacation, so its going to be awhile.
   / Standard L series owners POST YOUR SMOOTH 3PT HITCH VIDS HERE #8
Thanks from me! I know I appreciate it and I'll be sitting on the edge of my seat. Throw an L3400 into the line up, please.
   / Standard L series owners POST YOUR SMOOTH 3PT HITCH VIDS HERE #9
I looked at 2 new (or near to new) L3800's this past week. Neither was what I'd call smooth, but both were marginally better than mine is.
Sean
   / Standard L series owners POST YOUR SMOOTH 3PT HITCH VIDS HERE #10
I just read on Orangetractortalk everything Kubota, That the problem is probably with the hydrolic fluid and or filter. If you have a jerky 3 point hitch, you should change your hydrolic fluid and filter. Also on my L 3000 DT, there is a knob under the seat that controls the rate of the 3 point hitch, try adjusting that is you have changed your fluid and filter and it still is jerky.
2017 Ford Expedition Limited SUV (A56859)
2017 Ford...
Pneumatic Grease Can w/Chevron Delo Starplex EP 2 (PARTIALLY USED - AIR HOSE REEL NOT INCLUDED) (A59076)
Pneumatic Grease...
12 X 20 CAR PORT (A58214)
12 X 20 CAR PORT...
2015 Ford Transit Cargo Van (A54814)
2015 Ford Transit...
LOT OF CHAINS (A58374)
2007 Ford F-550 Crew Cab 11ft Flatbed Truck (A55852)
2007 Ford F-550...
