Hydraulic Oil Cooling Fan
   / Hydraulic Oil Cooling Fan #1
tlb13057
near Austin, TX
PT425 (2003)
Has anyone ever replaced the (plastic) hydraulic oil cooling fan on a (2003) PT425? Power-Trac price is very high. Made by SPAL (Italian). I have found a couple (jaycorp technology) but not exact matches to the one on the tractor.
Thanks,
-Sundown
   / Hydraulic Oil Cooling Fan #2
When I checked, the one for 1445 is on the SPAL USA website. SPAL has an odd way of showing diameter on their specification sheets. You may want to double check and make sure that you are measuring the fan the same way that SPAL does. They measure the fan diameter on the inside; fitting to fitting or max diameters are different (cf the 1445 fan). I don't know that the SPAL has any more fans than Jay Corp. though.
SPAL sells higher performance fans of the same diameter, but since they draw more current (for the 1445 ~300% more current 100% more air), they would probably need an additional relay for control to minimize the strain on the thermostatic switch.
Good luck.
All the best,
Peter
Thanks,
-Sundown
   / Hydraulic Oil Cooling Fan #3
Thanks,
-Sundown
I thought my fan had gone out on my 425 but when checking the sensor, that appeared to be the problem. Ordered another from Power Trac which did not work so I wired direct to a switch from the battery which is working very well and at a very low cost.
PJ
   / Hydraulic Oil Cooling Fan #4
PJ
My sensor went out, too and I wired the fan direct to the battery with a clip/plug. I just plug the fan in before I start the tractor and unplug it after I'm done.
   / Hydraulic Oil Cooling Fan #5
My sensor went bad too. I replaced. It seems silly to wear the fan, load the generator, and force more cold air over a cold engine.
   / Hydraulic Oil Cooling Fan #6
If I remember correctly, the sensor is a washing machine thermacouple or something along that line.
   / Hydraulic Oil Cooling Fan #7
Yeah, I thought about that. Then I thought about it some more. Once the sensor turns the hydraulic cooling fan on, it stays on and never ever shuts off until I turn the tractor off. Winter or summer, that's the case. At full throttle, the internal engine fan is blowing massive amounts of air over the engine continuously right from the start. Since the engine compartment is open on all four sides with steel mesh I don't think the air pulled out of the engine compartment by the hydraulic cooling fan has any measurable affect on the engine temperature at all.
   / Hydraulic Oil Cooling Fan #8
What is the internal engine fan? I did not notice one on my PT-425?
   / Hydraulic Oil Cooling Fan #9
Right here under the back shroud driven by the crankshaft... All air cooled engines have them.
2013 PETERBILT 386 TANDEM AXLE SLEEPER TRUCK (A53426)
2013 PETERBILT 386...
John Deere WG48A 48in Walk-Behind Mower (A51691)
John Deere WG48A...
2025 JOHN DEERE 408R LOT NUMBER 10 (A53084)
2025 JOHN DEERE...
UNUSED JCT HYD AUGER (A51248)
UNUSED JCT HYD...
1973 JEEP RENEGADE (A51247)
1973 JEEP RENEGADE...
JOHN DEERE 560M LOT IDENTIFIER 37 (A53084)
JOHN DEERE 560M...
