Is my treehouse safe?
   / Is my treehouse safe? #21
Unless the kids start moving major appliances into the tree house you've got plenty of support. Just watch for the tree growth, it will also spread the joists apart & start pulling nails over time as the structure stretches, although this will take a few years. MikeD74T
   / Is my treehouse safe? #22
Instead of bolting the frame directly to the tree, he used big eye bolts and suspended the tree house with cable.
I am a big fan of the suspension/cable method personally.
Think like a REALLY BIG deer stand...
Now we're talking!
Finished! See pics below. Still need to reinforce some... also going to reinforce the ladder steps with some type of steel L-shaped Brackets under each step... probably will add a door at some point later.
   / Is my treehouse safe? #24
only thing I see wrong with it is you should have built it with it having a tree up the middle of the floor leaving enough room for passage through as a fire escape pole :D, Just kidding;) really you done a great job:thumbsup: I wouldn't worry about how long it will last Your children be grown and moved out before that tree house will fall, which I doubt ever....
Your children are lucky they have a skilled father that can fabricate nice things for them..... as for me I was on my own, having to build a tree house my self at 12 years old, what a mess that turned out to be:cool: who would know later on in years I would become a master carpenter:D
   / Is my treehouse safe? #25
Almost done. Just need to add the fireman pole (a must have when I built a fort for my kids many moons ago).
   / Is my treehouse safe? #26
I am now trying to decide which one of 3 options to do with additional lag bolts... but I also want to minimize the # of additional bolts I put into the trees, I think.
option 1: put a block of wood under each plank end with two 5/8" x 8" lag bolts = 6 lag bolts per tree! (3 for each plank end... 1 through plank and 2 in support wood).
option 2: block of wood + 1 lag bolt under plank end + a bracket on the tree that fits above the plank end with 4 wood screws through the bracket into the tree and another 4 screws through the bracket and into the plank = 3 lag bolts per tree + 4 wood screws
Option 3: A 2 foot piece of 2x10 on the inner side of the tree (opposite side of the tree from where the plank ends meet on the outside) attach the wood piece to the tree with 2 lag bolts so that it spans the 2 plank ends... each end "resting" on an end of the 2 foot board.
I will also strap the ends of the planks to each other with a steel strap on all the options.
Which of these options will be the strongest? should I worry at all about putting a max of 6 bolts in each tree vs. the 2 in each tree currently?
Thanks.
I am hesitant to screw stuff into trees for fear that I'll damage or kill them. I would probably use something like option 2 (support on the inside) with a large "U" bolt made out of threaded rod to secure it around the tree with rubber hose or similar to protect the tree bark. Probably overkill. I kinda felt bad about screwing the clothes line pulley into the tree. :rolleyes:
   / Is my treehouse safe? #27
BTW - That is a very cool tree house. Your kids are gonna have a ball playing in it :thumbsup:
   / Is my treehouse safe? #28
I really like now nice it looks. You did a beautiful job on it.
The 2x10's might last forever, or they might sag on you. Worse case is that one will crack and fail on you. If it was me, I would double up on them and use liquid nails to glue them together, and screw them together every foot, top and bottom, with deck screws.
I would use three lags bolts at the end, or drill all the way through the tree and use two half inch or larger bolts at the end of each board.
How did you attach the floor joists to the beams? If you just nailed through the end of the beam into the end grain of the joists, then they will come loose as the wood dries out and the deck moves. Joist hangers would be the best thing to use. You can add them in there easy enough. They make them with angles too, so you should be alright there.
You probably need to spend a couple hundred bucks more to get it there, but then you should have peace of mind for a couple of decades.
Eddie
   / Is my treehouse safe? #29
Great Deer Stand... I like the way you designed / disguised it as a tree house to get the wife's approval :thumbsup::thumbsup::thumbsup:
   / Is my treehouse safe? #30
Looks great. I vote for a firemans pole too.:thumbsup:
Keep a can of wasp spray handy!
GEHL RT175 GEN 3 SKID STEER (A52707)
GEHL RT175 GEN 3...
2005 EAST 45' WALKING FLOOR TRAILER (A54756)
2005 EAST 45'...
205196 (A52706)
205196 (A52706)
1991 International 4900 Box Truck (A55315)
1991 International...
Year: 2014 Make: Ford Model: Taurus Vehicle Type: Passenger Car Mileage: Plate: Body Type: 4 Door (A56859)
Year: 2014 Make...
2007 Yamaha Rhino 660 (A55315)
2007 Yamaha Rhino...
