BX23 Question about the hydraulic lines to the backhoe
   / BX23 Question about the hydraulic lines to the backhoe #11
without the WSM, I cant tell you exactly what its going to do to your tractor when the pwrbyd hose not hooked up. it only takes a moment when not hooked up to BH. so why not do it for a piece of mind?
   / BX23 Question about the hydraulic lines to the backhoe #12
Does that mean that when the backhoe controls are in neutral that the hydraulic fluid passes straight through also ?
That is correct. Ever felt the hoses? They get warm right?
   / BX23 Question about the hydraulic lines to the backhoe #13
If you don't connect the hoses does that cut out fluid flow to other circuits ?
Sure does, and you can overheat the fluid, or worst damage the pump if continually operated like that.
   / BX23 Question about the hydraulic lines to the backhoe #14
Another thing you should do is connect the (I hope I got this right) in and out together on the backhoe. If the outriggers slump during storage, enough pressure will build in the hoses and against the connector port that it may be difficult to impossible to connect the hoses to the tractor. I needed mechanical help to open the port and was rewarded with a spray of hydraulic oil.
Radioman: I only wanted to know for diagnostic purposes. They are connected.
KenyD: Actually when I noticed they were quite hot I got worried.
Jabroni: that is what I did, but I also rocker the control leavers to let the backhoe go into a equalize pressure (with the engine stopped).
Now I know why the fan for the HSD is so important, the hydraulic fluid gets really hot.
   / BX23 Question about the hydraulic lines to the backhoe #16
I have a strap between the to outriggers so that they can't slump but I do also connect the hoses together. Keeps them clean too!
I just layed it out completely flat.
Of course that takes a lot of room, but as it was my first time I wanted to keep it simple.
It was also the first time that the backhoe had been demounted.
Original owner only used backhoe and loader and used it for road upkeep.
Best 30' Grain Drill (A50514)
Best 30' Grain...
2016 Laymor SM300 Towable Ride-On Rotating Sweeper (A50322)
2016 Laymor SM300...
Toro Workman Cart (A50322)
Toro Workman Cart...
John Deere 350 PTO Manure Spreader (A52128)
John Deere 350 PTO...
2010 Triple B Gooseneck Inclosed Car Trailer (A50514)
2010 Triple B...
2018 Infiniti QX30 Premium SUV (A50324)
2018 Infiniti QX30...
