radioman
Super Member
without the WSM, I cant tell you exactly what its going to do to your tractor when the pwrbyd hose not hooked up. it only takes a moment when not hooked up to BH. so why not do it for a piece of mind?
Does that mean that when the backhoe controls are in neutral that the hydraulic fluid passes straight through also ?
If you don't connect the hoses does that cut out fluid flow to other circuits ?
Another thing you should do is connect the (I hope I got this right) in and out together on the backhoe. If the outriggers slump during storage, enough pressure will build in the hoses and against the connector port that it may be difficult to impossible to connect the hoses to the tractor. I needed mechanical help to open the port and was rewarded with a spray of hydraulic oil.
