garbage truck pump on logsplitter
   / garbage truck pump on logsplitter #1
me0418840987
Theresa(Milwaukee) WI
ford 800
I have an opportunity to aquire a hydraulic pump from the front of a garbage truck. Does anyone know what pressure these flow? I have a splitter with a
7" x 48" cylendar on it. It currently runs with a 11 hp briggs engine and a 16 gpm pump. I want to install that massive pump attached to a Ford 300-I 6 / 165 hp engine from a 1981 F-100. Volume should not be a problem, as I found most new Garbage trucks spec a 40+ gpm pump, but cannot find at what psi and rpm this happens at. May sound rediculous, until you realise that I have over a 2 minute cycle time with the small 16 GPM pump. I heat the shop and the house, with an outdoor stove, and my aunts house, and the maple syrup operation and between all of them, I make and use about 25 full cords per year. Thank you.
Where can I source a 40 gpm flow rate valve with 2,500 psi + capacity, or can I just use the valve from the truck and block off output ports as needed? Splitter: 10" I beam, Dodge Grand Caravan axle, 7x48 ram C load trailer tires, 1-3/4 thick end plate backed by a peice of railroad track, 2- 7,000lb trailer jacks, and a small 11 hp Briggs, because the 16 hp twin cyl briggs I was given was stolen out of my shed. Only problem is the cycle time. Haven't found anything that can stop it yet, Including green elm knots. Don't have any bur oak to try, but would like to find a knotty crotch from one, just to see what happens...
   / garbage truck pump on logsplitter #3
Splitzilla is definitely an understatement! Surpluscenter.com should have everything you need. I don't have any ideas on the pump you're looking at, the largest I've seen was a 30gpm pump powered by a carbureted Toyota 22r 4 cyl from about 1985. The splitter configuration was basically 2 splitters side by side built into one trailer, each with its own 3" dia 24" stroke cylinder ram. It was valved so that when one side was splitting (extending) the other side was retracting. It would work a pair of twenty year old bucks to death, but was set up to be run by one person like that.
That's about the extent of my wood splitter knowledge. ;)
   / garbage truck pump on logsplitter #4
Best bet would be to get the tag off the pump if it's still there. If not, find out the brand as it's usually cast into the housing and do a search on the companies website.
Guessing I'd sy the pressure would be around 2-2200psi but that's all it is, a guess. You sure it's not a variable displacement pump?
.....block off output ports as needed.....
You could as you're not going to get any flow unless you move a spool but make sure you can't accidentally move the spool on that section, again provided it's not a var. pump. A safer solution would be to join the ports on each section with a small section of hose if there's any chance of movement....Mike
I have no idea what it is, I will take a can of brake parts cleaner and a stiff brush the next time I go to the salvage yard. My hydraulic knowledge is limited to:
1) replacment of existing parts, and
2) never check for leaks with bare skin, and
3) when all else fails, ask someone who knows better
The log splitter was already built, I just made it slightly larger.
I extended the frame, and went from a 4 to a 7 " cyl.
Bigger, but not big enough pump and motor.
   / garbage truck pump on logsplitter #6
Here is a single lever spool valve. No detent
Surplus Center - 1 SPOOL 45 GPM BRAND DA OC VALVE
Log splitter valve. 25 GPM
http://www.surpluscenter.com/item.asp?item=9-7724&catname=hydraulic
   / garbage truck pump on logsplitter #7
Might as well put a 6 or 8 way wedge on it because that cylinder is way overkill for a single wedge.
   / garbage truck pump on logsplitter #8
Does it look anything these pumps?
You should know which way the pump is supposed to turn, as some of them turn the other way.
If you go shaft to shaft. the pump has to turn the opposite of the engine.
As far as using the valve on the truck, do you know if it is open or closed center? You could plug the unused ports, and remove the levers.
Does it look anything lke this?
Wet Line Kits - Products - PERMCO HYDRAULIC PUMPS
If that 7 in cyl had a 2 in shaft, and you had a 30 GPM pump, the extend time on the cyl would be about 16 sec, and retract would be about 14.5 sec, for a total cycle time of 30.5 sec.
To achieve 30 GPM's, at 3000 psi, will take about 62 HP.
They do make a fast extend log splitter valve, but not at 40 GPM.
   / garbage truck pump on logsplitter #9
If the pump was on a garbage truck, the pump would mounted directly on the engine shaft to shaft and I am guessing the diesel trucks run at about 2500 to 3000 max.
You can install a 3000 psi hyd gage and can see the pressure when hooked up.
7 in cyl
2 in shaft
3000 psi
115,000 push force in lbs
106,000 pull force in lbs
   / garbage truck pump on logsplitter #10
A couple of things to check on this pump.
1) Is it a pressure compensated piston pump?
2) Is it a fixed displacement gear pump?
If pressure compensated does it require a charge pump?
Can you take some pictures of the pump and post them. This would help the members ID the unit and then we could provide you with more info.
On the valve side. If you access to original valves look at them. They might be sectional style valves that are held together with tie rods. If this is the case you may be able to remove a couple of sections and just use the one you need. Again pictures would help.
With this large of pump you will need a larger reservoir, return filter, etc. Have you allowed for this?
Roy
2019 UniCarrier 5k Propane Forklift (A56857)
2019 UniCarrier 5k...
Kivel Pallet Forks (A57149)
Kivel Pallet Forks...
2002 AMERITRAIL 32FT GOOSENECK TRAILER (A58214)
2002 AMERITRAIL...
Kawasaki Mule 2510 4X4 Utility Vehicle (A55853)
Kawasaki Mule 2510...
(5) Seats (A57149)
(5) Seats (A57149)
2001 Fruehauf Step Deck (A57148)
2001 Fruehauf Step...
