Sweet!
the guy that owned that 950 had a bunch of issues.
it had ( stil does ) the rad out of a small import car in it.. inlet tube is on the wrong side.. I had to search for a molded rubber hose, and got lucky and found one that fit perfectly. was cheaper than buying a new rad.
and he owned no torque wrench.. 80% of the bolts and nuts were tightend till they snapped..then backed off a lil..
garden hose ( YES ) held a vw gas tank free floating in the cut out hood .. whih IMHO.. used to be a nice LPG hood.. but had been torched out wide for the vw tank.
had a gasline from a gm truck on it.. part number on hose said so... vw tank had a hole in the top and was patched with fiberglass!!!
ignition power switch was a bare wire jambed down into the + bat cable when you wanted to run it... dash had been thru a fire at one time.. no doubt from the special wireing and gas tank conversion...
lower rad hose was 2 piece of hose and a metal right angle ? tent pole fitting, that was rusted out and seeping.... bat box bottom was rusted out and battery laying on throttle tension disc... ( dead battery to boot.. bad cell )...
yep.. that's also the one with that had the welded up pa rims. the rims that looked pristine with -0- rust. took me all winter to dismount them monster 14.9's and carefully cut that darn center out and save the pa rims so they still functioned.
oh yeah.. and the WELDED linkage under the lift cover.. OMG! WTF?!?
some people...
soundguy
