Front-End Loader Cutting edge vs. Tooth Bar on the Bucket???
   / Cutting edge vs. Tooth Bar on the Bucket??? #1
MossflowerWoods
Super Member
Fredericksburg, VA
Kioti DK50SE HST w/FEL, Gravely 60" ZTR Mower. Stihl MS290 (selling), CS261, & FS190 + Echo CS400 & 2010 F-350 6.4 PSD snowplow truck
I'm buying my tractor and getting it outfitted.
Can someone explain the pro/cons and useage of a Tooth Bar and a Cutting Edge.
Which one and why, or do I need both?
I will be doing brush clearing and leveling and cleaning up land after the mulcher grinds stumps & slash. I will also be clearing and putting in trails, maintaining dirt access roads for fire prevention/fighting etc.
Thanks in advance,
David
   / Cutting edge vs. Tooth Bar on the Bucket??? #2
My toothbar gives my FEL enough of an underbite to make picking and moving both woody debris and solid objects a little easier. It's also good for "raking" out surface roots. I've also hung a chain from a tooth or two and used it to suspend and carry various items. Most recently I used it to remove an old signpost.
I go toothbar-free when working snow or backdragging gravel in the driveway.
   / Cutting edge vs. Tooth Bar on the Bucket??? #3
Your bucket already has a cutting edge on it.
The toothbar is an add-on and makes digging easier. Also useful for brush moving.
I want one real bad.
http://www.wrlonginc.com/FTB.htm
   / Cutting edge vs. Tooth Bar on the Bucket??? #4
A tooth-bar is a very handy and fairly inexpensive addition to a bucket.Easily removed for back blading,snow removal ect.Mine with the Green's Machine Thumb works great for brush removal.A lot easier digging with the tooth-bar on.
NY,
I'm being quoted $350 for the toothbar.
I LIKE the Green's Machine Thumb!!! That may be just the ticket for me!
Thank you!
David
   / Cutting edge vs. Tooth Bar on the Bucket??? #6
NY,
Thank you!
David
It is, the ones from WRLong look way too large for your application.
   / Cutting edge vs. Tooth Bar on the Bucket??? #7
Thanks in advance,
David
Hi David,
I think you are talking about a "Hard Edge" & Tooth bar.
Your bucket has a built in cutting edge. Depending on how much and how hard you use it. it could last a long long time. For hard use on concrete or lots of stone you want a Hard Edge.
If you get a tooth bar. you want it to easy to remove or put on. It's not real goof for smoothing driveways or roads.
Hope that helps.
   / Cutting edge vs. Tooth Bar on the Bucket??? #8
Your price on the tooth-bar is about right.the expensive part of the grapple is the third function valve.You may want to include it with your tractor purchase.
$700-$1,000.I think I paid about $470.00 for the thumb.
NY,
Did you do the thumb install yourself or did you find a dealer?
I was talking to a different dealer and he told me the hoses, quick connects etc wil set me back over $100 each PLUS I still will need to drill or weld the thumb on.
That might be beyond this computer geeks capabilities.
David
   / Cutting edge vs. Tooth Bar on the Bucket??? #10
By all means bolt the thumb on.You may want to remove to do dirt work etc.
I had to weld an angle on top and bolted thru.the angle also reinforces the top of the bucket.
2020 Terex RL4 Towable Light Tower (A55851)
2020 Terex RL4...
2012 New Holland BR7070 Round Baler with XtraSweep and Net Wrap (A57024)
2012 New Holland...
Adams 5 T Spreader (A55301)
Adams 5 T Spreader...
34" EXCAVATOR BUCKET (A57192)
34" EXCAVATOR...
2005 Nissan Frontier Crew Cab Pickup Truck (A55852)
2005 Nissan...
40' CONTAINER (A57192)
