My 1st. 3 Beads
   / My 1st. 3 Beads #11
Yes turn both up! If you're right handed, place the gun back even with your right shoulder, bend your head down in front of the gun. Do you have the contact tip sticking out from the nozzle a little bit? Note the chart I posted.
Here's a Mig weld I made for a test I posted here, see how hot my weld is compared to your's?
   / My 1st. 3 Beads #13
The Push vs Pull on a MIG debate has gone on for years.
I do both. There, IMO, is no difference in weld quality, penetration, look, etc, as long as you have the welder set right. So do what you are comfortable with.
I personally let the job dictate what I do. I am right handed as well. Sometimes, when working on an immovable object, the job dictates a right to left weld, therefore I pull. Sometimes, its the opposite. It just depends.
But you are correct, you get a better view of the "puddle" when pulling. Onve you get the feel of the motion, what it looks like, and what it sounds like, try pushing. Because while you cant see the puddle as well, you have a MUCH better view of where you are going without the torch and your hand in the way....
For example, when butt welding two flat peices together, and you have a tight fit and try pulling, it is very easy to veer off course and lay a really nicce bead, but only on one of the plates. Pushing is MUCH better for visibiliy in a place like this. Corner welds, or TEE welds, when you have two peices at 90 degrees and you are welding in a "corner", it is easier to stay on course no matter wether you push or pull.
   / My 1st. 3 Beads
Yeah, no doubt you can see the heat, much smoother! The tip does stick out a little, there's no adjusting that, is there?
I did some 'off roading' with one of my beads, thought I was doing great untill I looked at it..
Thanks both of yous, Appreciate the tips! :thumbsup:
   / My 1st. 3 Beads
This is the extent of my MIG experience to date:
   / My 1st. 3 Beads #16
Looking good so far. Try some "pushing" and see if you think it will help you to keep it "on-road":laughing:
   / My 1st. 3 Beads #17
I'm not familiar with the Ironman welders, I understand they're great machines! Can't say I've ever seen one. I've been using Tweco guns for well over 30-years, you just slide the nozzle up and down on the defuser as needed. Anymore all I use is the model 2. No more of that 400 to 500-amp welding for me, 200-amps is plenty.:laughing:
   / My 1st. 3 Beads
That looks like a good sized gun. (on second look, it seems like about the same size as mine) This nozzle slides off, but I didn't hear about it being an adjustment.. 'stick out' refers to the wire that you start with? or is it the nozzle to tip distance that they meant?
   / My 1st. 3 Beads #19
Stick out is distance from tip of wire to contact tip.
The relationship of the contact tip to nozzle, be it the contact tip up inside the nozzle, or the contact tip sticking out of the nozzle is a personal preference. As with many things in welding there is no right or wrong way, you have to find what works best for you!;)
   / My 1st. 3 Beads
Stick out only exists until you pull the trigger, it seems. They should have probably called it 'keep it close', or 'keep it uniform', right? They make a big deal of cutting the wire off within a sixteenth of an inch (of 5/16"), but what difference does that make? :confused2:
I guess they just mean don't start with an inch..
Tennant 800 Ride-On Street Sweeper (A53421)
Tennant 800...
2005 Chevrolet Trailblazer EXT 4X4 SUV (A51694)
2005 Chevrolet...
2015 JOHN DEERE 544K WHEEL LOADER (A51406)
2015 JOHN DEERE...
2019 CHEETAH T/A CHASSIS TRAILER (A53843)
2019 CHEETAH T/A...
2012 JOHN DEERE 13-INCH REAR WHEEL SPACER FOR 10 BOLT HUB (A53473)
2012 JOHN DEERE...
Heavy Duty Jumper Cables (A51694)
Heavy Duty Jumper...
