Fluids for 1980 Ford 8000 dump truck with CAT 3208
   / Fluids for 1980 Ford 8000 dump truck with CAT 3208 #1
BoFuller
Arizona
2008 Kubota L3400
I am headed up to my ranch this next weekend and would like to have some oil and hydraulic fluid on hand in case I need to add any. What type of oil would this truck use in the engine?
Also, if I needed to add hydraulic fluid to the box for the dump bed, is there a certain kind?
Thanks for any help!
   / Fluids for 1980 Ford 8000 dump truck with CAT 3208 #2
The CAT 3208 just needs a good quality motor oil, rated for diesel engines with a turbocharger. Probably the best-known would be Rotella-T. I have 3 diesel tractors and 2 diesel trucks, so I buy oil from a local fuel supplier. I use the Exxon XD-3 or Mobile Fleet in 15W-40.
The hydraulic system needs a good quality hydraulic oil. Just about any clean hydraulic oil will do, but to keep things simple, you can use the hydra-trans fluid that you put in your tractor. It cost a little more than plain hyd oil, but it shouldn't hurt anything. (except your wallet if the hyd system on your truck leaks a lot)
   / Fluids for 1980 Ford 8000 dump truck with CAT 3208 #3
What he said....
The 3208 is not one of the favorite Cat engines ever built... way underpowered in most applications, but seem to just run forever unless they are on a FRAC or Firepump application...
What he said....
??? WHat does that have to do with what oil I should use??? :confused2:
Thanks! THat helps a lot. :thumbsup:
   / Fluids for 1980 Ford 8000 dump truck with CAT 3208 #6
nothing... I get "stress disorder" when I see the numbers 3208!!.. :laughing:
Like others have said, just use your favorite diesel engine oil... Use CI or CI+ rated oil if you can find it... if not, you will have to run CJ rated..
Mobil still sells CI rated, also offered up as Cat oil, but they are the same minus the labeling.
I am not sure who else..
2016 John Deere 17 Mini Excavator (A47477)
2016 John Deere 17...
2015 Toro Workman MD Utility Cart (A53421)
2015 Toro Workman...
2012 Ram 1500 Crew Cab Pickup Truck (A53422)
2012 Ram 1500 Crew...
UNUSED WOLVERINE PFF3-13-45W PALLET FORK FRAME (A54757)
UNUSED WOLVERINE...
2010 John Deere TX Gator 4x4 Utility Cart (A52377)
2010 John Deere TX...
Manac Walking Floor Trailer (A50322)
Manac Walking...
