Aaargh! 3-pt hitch not lifting any weight.
   / Aaargh! 3-pt hitch not lifting any weight. #41
Yes let us know if you find anything. I sure would like to know if it's what I'm thinking it is. Glad I could help and that you got a manual.
Lee
I pulled the housing off today.
I will post some pictures later tonight or tomorrow. Nothing sticks out as a problem so far.
I removed the control valve from the housing, the o-rings look to be in good shape. I cleaned it out in Naptha.
Before I pull it apart completely, I was wondering if I could re-assemble the valve in the housing and test for a leak between
Some Pictures
Any ideas on getting the main spool out? Is it just threaded?
   / Aaargh! 3-pt hitch not lifting any weight. #44
project_X,
Frist off I have never had one apart and I'm uneasy telling someone how to do something unless I have done it. I have all my life took things apart and put back together for a living or just to see how it made. Look at it this way, it doesn't work now so to me it's a win, win if it works when you get it back on.
By looking at the 790 parts list I would remove plugs #10 I see one is in deeper then the other. I can't see why or how it would screw in because it has to move. If you take bolt 29 out I would not turn on nut 30 it adjust the push pin #26.
You have sure sparked my interest in this project.
project_X,
Both the #10 plugs are the same depth, in the picture 1 has been removed, the other didn't want to come out (I need to drag my drill press vise out to my shed to hold it).
I don't plan on removing 29, as you can see it looks to be "factory sealed" with the corner bent against the bolt.
Hopefully pulling #7 shows me something
   / Aaargh! 3-pt hitch not lifting any weight. #46
I think when you remove 29 all of 31 comes off. If you don't find anything at 7 I would go on with the others, they look easy to do and have no adjustments. Also only need some o rings. I'm been thinking it's a broken spring or a open poppet valve.
29 must be removed to get 7 out. if you push on 7 the assembly 31 moves out and is pulled back by the spring.
i removed both 3 and 22, o-rings and springs looked good.
i'll take 7 out tomorrow.
   / Aaargh! 3-pt hitch not lifting any weight. #48
"29 must be removed to get 7 out" I kind of thought that and you haven't found anything. wow only 1 more thing to go and cleaning. Sure wish you could find something. If it was dirt we might not ever know for sure if it was dirt or a flat o ring. Are you going to put new o rings in?
i have to measure each one and see if i can find metric ones next week....
Sizes are in the parts diagram. I'll have them tomorrow.
2023 Kubota M4-061 Deluxe MFWD Utility Tractor with LA1154 Front Loader (A55315)
2023 Kubota M4-061...
2001 Ford F-550 Liftmoore 6036 3 Ton Crane Service Truck (A56858)
2001 Ford F-550...
2017 Chevrolet Tahoe SUV (A55853)
2017 Chevrolet...
Paladin 48" Skid Steer Pallet Fork Attachment, S/N 549834, Asset# 67 (A59076)
Paladin 48" Skid...
2022 Schulte SMR-800 Multi Rake Landscape Windrower (A56435)
2022 Schulte...
CHAMPION OUTBOARD MOTOR (A58374)
CHAMPION OUTBOARD...
