J_J
Super Star Member
- Joined
- Sep 6, 2003
- Messages
- 18,973
- Location
- JACKSONVILLE, FL
- Tractor
- Power-Trac 1445, KUBOTA B-9200HST
With a 1000 lb load on the 3pt, can you tell me what pressure you read with the 3pt lever up, but not at the relief pressure?
It will take a very large load to test the safety valve.
If you get high pressure, using the 3pt lever, that means that the cyl has fluid and is at the end of the stroke, and if the load is not lifting, the relief should go off.
Seems like a while ago, someone had trouble with their 3pt, and the 3pt cyl was coming out of the cyl bore to far and the fluid was just flowing past the cyl seals into the sump.
