PTO Connection Styles
   / PTO Connection Styles #1
foggy1111
Elite Member
Nisswa, MN
Kubota L 3560 HSTC, 805 Loader
I have two styles of PTO connections on my various 3 point equipment. (1) I have the spring-loaded, side push-pin type and (2) The air coupling style with a circular ring to pull back and slip onto / off the shaft.
I MUCH prefer the style #1 push-pin. Easy to do. Seems I need a third hand for the other style.....and most often I need to get my foot (or my wife) to push the coupling onto the PTO stub because it takes two hands to pull the retainer collar back....and/or....it requires a few "choice" words to get hooked up.
Anyone have a helpful method to hook up this "air-coupling" style joint?
   / PTO Connection Styles #2
I also have both types of locking devices (as you described).
To make it easier, I uses a bungee cord attached to a convenient spot on the implement's frame to support the weight of the PTO drive shaft.
Give it a try...you'll find it does make it easier.
2017 Ford Explorer AWD SUV (A51694)
2017 Ford Explorer...
UNUSED IRANCH EXCAVATOR ATTACHMENT SET (A54757)
UNUSED IRANCH...
UNUSED LANDHONOR UNIVERSAL ADAPTER PLATE (A54757)
UNUSED LANDHONOR...
2014 Ford F-450 Dump Truck, VIN # 1FDTF4GT9EEA61310 (A54865)
2014 Ford F-450...
2018 CATERPILLAR 299D2 XHP SKID STEER (A52705)
2018 CATERPILLAR...
UNUSED IRANCH HYD EXCAVATOR THUMB CLAMP (A54757)
UNUSED IRANCH HYD...
