Draw bar with pintle hitch for batwing?
   / Draw bar with pintle hitch for batwing?
Look at one of my early pictures. 4, - 1/2" Bolts hold the hitch to the shank. Maybe grade 5 or above. The single pin that holds it in the receiver is only 5/8" and it was to pull a dump trailer with around 6 yards of soil in it.
Be nice to use bolts that match the hole size in your draw bar.
What I mean is if I mounted the 2" solid square tube to the top of the drawbar with (2) 1/2" hardened bolts. 5,000+ lbs is a lot for 2) 1/2" bolts. maybe I could do 3 bolts or use 5/8" grade 8 bolts.
1900 Pounds of tongue weight does not sound right to me. Sure be nice to see a picture of this thing.
Needs to be strong. Pulling a batwing over bad ground creates more stress than pulling a trailer down the road.
Here's the mower
Woods Equipment Company - Woods BW1260 Batwing
   / Draw bar with pintle hitch for batwing? #22
What I mean is if I mounted the 2" solid square tube to the top of the drawbar with (2) 1/2" hardened bolts. 5,000+ lbs is a lot for 2) 1/2" bolts. maybe I could do 3 bolts or use 5/8" grade 8 bolts. ( Use bolts that match the holes in the draw bar. Grade 8 is fine, but doubt that they are really needed. 2 Will hold all that your draw bar is capable of.
1,900 Pounds of static weight, then it jumping up and down is going to over load your rear axle and draw bar.
Needs to be strong. Pulling a batwing over bad ground creates more stress than pulling a trailer down the road. Construction sites are no exactly "down the road".
Here's the mower
Will go look at the Batwing.
   / Draw bar with pintle hitch for batwing? #23
The difference is that the hammerstrap will only have to hold 1/2 or less of the load. When the lunette is sitting on the drawbar, the hammerstrap is probably providing 1/3 of the forward to back strength (draw it out and you will see what I mean).
When the lunette is in the middle, it will be 1/2 and 1/2 (between the hammerstrap on top and the drawbar on bottom).
Whereas, if you use a pintle hitch, those bolts will have to hold the whole load all of the time.
Aaron Z
STEEL SLINGS (A54757)
2017 NISSAN NV200 VAN (A51406)
2017 NISSAN NV200...
2012 Freightliner M2 106 Asphalt Pothole Patcher Truck (A54814)
2012 Freightliner...
UNUSED GAS CADDY (A54757)
UNUSED GAS CADDY...
2017 Hino 268 20ft Flatbed Dump Truck (A52377)
2017 Hino 268 20ft...
John Deere 2640 2WD Tractor with 146 Front Loader (A55218)
John Deere 2640...
