My 202 just died, help
   / My 202 just died, help #11
Do you have a NAPA near by..?? They should be able to get it pretty quick, if not in stock. If you need to get done PDQ, I'd see if your local parts place has one the same size, and go with it... Maybe get the proper tune up kit asap...
I'm thinking coils are pretty generic, as long as it fits your space/clamp you have.
Did you try using a test light, to check for current..?? No use throwing parts at it, until you narrow it down, and maybe still not correct the problem...
Could even be the insulation off of a wire grounding out, and losing current along the way. Check for current, even through the side of the distributor, if you find it that far, to the inside.
Are the points even breaking..?? Sometimes they can get a small teat on them, and make them not work. Maybe just burned, and need cleaned/filed, and readjusted.... They won't last long once they are filed on, but should get you through a project...
I do have a NAPA nearby, tried to call them today but closed on Sunday. Unfortunately I have to go have a procedure done at the doctor tomorrow. Should only be laid up a day or two before I can do light duty work at least.
I did check the battery cables visually and they look good since they are pretty new, no signes of breaks, etc. I didn't remove the points, I just watched them as I turned it over and didn't see spark. I will see if I can get a tune-up kit, maybe new coil, coil wire and plug wires too as they all look pretty old anyway. I guess I could wait and buy at test light first, any suggestions on a good one that wont cost an arm and a leg?
   / My 202 just died, help #13
It is a 12 volt. Twice a year I clean all electrical connections, re-grease them and put it back together. Not that much of a task, not a whole lot of electronics on the old girl.
Also, I buy the points / condensor and rotor button in a tune up kit, very inexpensive. My local JD dealer keeps them in stock. I learned the first couple of years I had the tractor that it will start to burn out points every 12-18 months, depending on usage.
The symptoms you've described sound more like a coil problem than points. When the points start to burn you'll notice your tractor run rougher and start harder. In your case, before it quit all together, it ran until it got hot, then shut down and wouldn't start. Typical signs of a coil problem. I thought you said you had just changed the coil recently, not that uncommon to get a bad replacement coil but can send a person into a tail spin when replacement parts fail so quickly.
Edit: test light can be purchased for around $10, just a simple probe with a clear plastic handle that has a light in it, ground wire from the top of the handle, looks about the size of a jewellers screwdriver.
Nope, I haven't replaced the coil, just the battery cables. I have seen those test lights before, wasn't sure if there was something different I should be looking for, sounds like the garden variety will do fine. I will call the New Holland/Kubota dealer up the road, they usually have a good stock of parts, if not them there is a JD dealer a little further away I can check with too.
The electrical connections are pretty rusty, not well maintained by previous owners so now it will be a little bigger task for me to clean them up but I guess I better do it.
   / My 202 just died, help #15
In my experience, this is true - especially in a pinch. When I was a just starting out as a hog/vegetable farmer with no land or equipment of my own I had to do a lot of scraping by. I saved old coils, plugs, wires, condensors, etc. I found nearly any part could act as a substitute for the correct part until $$ was available to fix it correctly.
OK, so I got a test light today and talked to my tractor mechanic buddy on the phone and here's what I have so far. Power at the key switch, power to that side of the coil, power on the other side of the coil intermittantly as I crank the engine (on and off as the points open and close he said), definitely no spark at the plugs. So that would seem to indicate a bad condenser and possibly rotor and cap (although they look fairly new, not burned or corroded) and maybe coil too. He could not stay on the phone with me as I tested so I hope I am not missing something.
Any other thoughts?
Can't find the parts local in stock, JD dealer had no trouble finding Tisco numbers and can get them quickest for reasonable price (New Holland/Kubota dealer could not even get a part number and Massey Ferguson dealer was only slightly better but is almost double the cost of the JD dealer for some reason).
   / My 202 just died, help #17
just curious, does that have delco-remy electrical equipment in it? i/d should be easy to find on the starter or generator.
also, if you unplug the coil wire from the distributor, hold the bare end, and give it a crank... you will know whether or not the coil is good. it's been a while since i had to try that, but i'm sure many people have done it and survived none the worse for wear...:thumbsup:
far as 12v coils, i think they have an internal resistor, or they don't.
have you got any old cars or trucks sitting in the bushes?
   / My 202 just died, help #18
[also, if you unplug the coil wire from the distributor, hold the bare end, and give it a crank... you will know whether or not the coil is good. it's been a while since i had to try that, but i'm sure many people have done it and survived none the worse for wear...:thumbsup:
Too funny, reminds me of when I was 11, we had an old elan snowmobile that just quit. Hung around dad all the time so he asked me to pull the plug wire off and hold it, he pulled the motor over.. "just checkin to see if she was gettin er fire son" .... followed by a chuckle. I learned pretty quick a screwdriver in the end of a lead gapped against the block works just as well, and a lot easier on the nerves.
Generator is Delco-Remy and that's what the previous owner had scribbled in the manual. I tried the screwdriver test and saw decent spark so maybe the coil is OK. No old cars sitting around but my buddy said I could get by with a generic 12v oil filled coil if I need one fast. I may see if the New Holland dealer can manage to round up something close for the condenser and maybe coil so I can try it today, they are only 5 mins away. If not I'll just get the parts from the JD dealer so I have the right ones for sure, hopefully by the weekend. I am going to see if I can get new coil/plug wires too as they look pretty old and nasty (as do the plugs) and part of the end of the coil wire fell off when I was testing it so seems like a good idea to replace them.
We had an Elan when I was a kid too. Neat little machine, wish we still had it. I remember riding it on Lake Winnipesaukee in New Hampshire in the spring when the snow was melted off the ice. The newer sleds with sliders need the snow to keep them sliding along the track but those old school bogey wheels on the Elan were greased so we had a blast spinning around on the ice.
   / My 202 just died, help #20
delco-remy has been used in general motors products since at least the '50's that i'm aware of.
at least you know the problem is between the coil wire-in at the distributor, and the sparks plugs.
doesn't seem likely that the plug wires or plugs would cause sudden demise, so that leaves the distributor.
are you sure you don't have a loose wire somewhere inside? points usually fail gradually, not sure about condenser... whereas if a wire got loose, rattled around a bit, and fell off something... maybe the insulation has worn off a wire and shorting to ground?
edit: oops... missed the part about the end of the coil wire falling off. that's really suspicious. ;)
2019 Kohler 50REOZK 50 kW Diesel Generator (A56857)
2019 Kohler...
2009 MULTIQUIP 25KW GENERATOR (A55745)
2009 MULTIQUIP...
2025 BrushFox HD-78STD 78in Rotary Brush Cutter Skid Steer Attachment (A56857)
2025 BrushFox...
2019 Ford F-550 (A55973)
2019 Ford F-550...
2025 GPS Trailer (A56857)
2025 GPS Trailer...
CHANDLER 500 BBL FRAC TANK (A58214)
CHANDLER 500 BBL...
