DJ54
Elite Member
- Joined
- Jan 20, 2009
- Messages
- 4,611
- Location
- Carroll, Ohio
- Tractor
- IH Farmall 656 gas/ IH 240 Utility/ 2, Super C Farmalls/ 2, Farmall A's/ Farmall BN/McCormick-Deering OS-6/McCormick-Deering O-4/ '36 Farmall F-12/ 480 Case hoe. '65 Ford 2000 3 cyl., 4 spd. w/3 spd Aux. Trans
Do you have a NAPA near by..?? They should be able to get it pretty quick, if not in stock. If you need to get done PDQ, I'd see if your local parts place has one the same size, and go with it... Maybe get the proper tune up kit asap...
I'm thinking coils are pretty generic, as long as it fits your space/clamp you have.
Did you try using a test light, to check for current..?? No use throwing parts at it, until you narrow it down, and maybe still not correct the problem...
Could even be the insulation off of a wire grounding out, and losing current along the way. Check for current, even through the side of the distributor, if you find it that far, to the inside.
Are the points even breaking..?? Sometimes they can get a small teat on them, and make them not work. Maybe just burned, and need cleaned/filed, and readjusted.... They won't last long once they are filed on, but should get you through a project...
