How do you transport your tractor & batwing bush hog?
   / How do you transport your tractor & batwing bush hog?
I'm not the least bit angry. in fact, the IH truck listed on eBay you linked to would probably work just fine.
Seller said it's over 9' high, so won't work. He wanted a fortune for it and with only 220HP, it wasn't exactly a pulling monster. I've had my fill of under 250HP heavy trucks. Airbrakes made it nice for stopping power though.
   / How do you transport your tractor & batwing bush hog? #82
So your truck is under 12k GVWR?
again.. it's in the barn, not in my pocket, but sounds about right. 11.9+change?
remember.. it's not a semi-tractor.. it's just an -old- 99 era F450 pickup truck. (cab/chassie )
soundguy
   / How do you transport your tractor & batwing bush hog? #83
View attachment 229396 Lamar 24ft with twin 7ks (those are 1800lbs alfalfa bales). Or just go with a YOTAView attachment 229397
gott laugh because my father will haul 6-1200 lb silage bales on a trailer behind his tacoma because my ton truck doesn't have AC.
We are stricktly Farm use and exempt from CDL but I always wanted a small road tractor. We always had Ford 700's and 800's on the farm and had way less breakdowns because they are built to haul, plain and simple, on the other hand probbably less miles too, hard to say.
   / How do you transport your tractor & batwing bush hog? #84
soundguy
I was under the impression that all '99 duallies were over 12k GVWR?:confused:
   / How do you transport your tractor & batwing bush hog? #85
wen i get the time I'll walk out to the barn and check.. just don't have it stored to memory...
soundguy
   / How do you transport your tractor & batwing bush hog? #86
mine is a 350 and only rated for 1500 lbs
but really only 10k
but really what does it matter what soundguys truck is rated for he isn't the one that ask the question just tried to help and give a answer
how come everytime people bring up cdl's you try to cause trouble
soundguy you should tell him to go buy one then he'll have one he can get the weight rating off of
   / How do you transport your tractor & batwing bush hog? #87
but really only 10k
but really what does it matter what soundguys truck is rated for he is the one that ask the question just tried to help and give a answer
cdl discussion does tend to bring out the spirit in some. :)
soundguy
   / How do you transport your tractor & batwing bush hog? #88
soundguy
and most dont know the laws what they are in flordia does'nt mean thats what they are in louisiana some states have tighter laws
   / How do you transport your tractor & batwing bush hog? #89
yep.. ditto that..
from what I hear.. florida has 'easier' transportation / DMV laws than MOST other states... at least that's what i get from listeningwhat some have to do to get tags and or licenses.. etc..
soundguy
   / How do you transport your tractor & batwing bush hog? #90
yep.. ditto that..
soundguy
louisiana is trying to pass a law now that if a vechicle has dual rear wheels u must have a cdl or farm tags no matter the weight rating
2018 FORD F-150 (A53843)
2018 FORD F-150...
2006 Magnolia Dry Fertilizer Tender Trailer - Dual Stainless Compartments, Hydraulic Doors (A53473)
2006 Magnolia Dry...
12-Wheel Pneumatic Pull-Behind Asphalt Compactor (A52377)
12-Wheel Pneumatic...
2001 INTERNATIONAL 4700 4X2 SERVICE TRUCK (A52706)
2001 INTERNATIONAL...
MASTER FLOOR HEATER (A53843)
MASTER FLOOR...
