4505 - Any information on this tractor??
   / 4505 - Any information on this tractor?? #1
Papasmith
Ruffin, NC
4500 Mahindra
I have been extolling the virtues of the Mahindra line to a neighbor. He has found a 4505 with only 430 hours, and an FEL. The owner says that it is in good condition. I figured logically that this must have come after the 4500 but, it appears that this is an older tractor that preceeded the 4500 line.
Can anyone give me some insight into this tractor as far as size, weight? Is it similar in design to the 4500 with the same filters, etc. Any comments on durability, suitability to task, and so on. Ideas generally on the price of this age unit?
Already looked at Tractordata. The information there is lacking.
Did you try doing a "search" rite here on TBN site ?
Also did you see this review from TBN member ?
Boone
Mahindra 4505 Reviews - TractorByNet.com
Yeah, first thing I did and always do but, really not much information. Also, found the review. What I was trying to determine basically is how closely does it resemble in terms of parts, engine, hp, and design to the 4500 of which I am familiar. My feeling now is that it is a completely different tractor. And, in that it doesn't appear to be a lot of them around, and thus far, not a lot of information, I don't feel I could recommend it to my neighbor. Thanks for the help thus far.
   / 4505 - Any information on this tractor?? #5
The 4505 is an older model then the 4500. My memory tells me it was discontinued arround 2001 to 2003.
   / 4505 - Any information on this tractor?? #6
   / 4505 - Any information on this tractor?? #7
Brandi,
I have never actually seen a 4505, but I think you would find the 2 at least 90% the same.
   / 4505 - Any information on this tractor?? #8
I have a 4505DI with a loader. Right now it has some engine problems due to it running way too hot twice - but I can post some specs and a picture or two. I have the service manual. It is a 4 cylinder. Good utility tractor.
Let me know what you need I can send some specs ater in the day.
Regards
Michelle
   / 4505 - Any information on this tractor?? #9
The Mahindra 4505 DI / 485 DI tractors are 100% WORKHORSES. I owned a 485 DI in the past and should have never sold it. It was a '97. Had about 1200 hours on it 5 or 6 years ago when I sold it. I kick myself all the time for getting rid of it!!
   / 4505 - Any information on this tractor?? #10
Go to the website TractorData.com You should find specs and info that you want on that website. Good Luck.:):tractor:
2009 Peterbilt 335 Cab and Chassis Truck (A55852)
2009 Peterbilt 335...
2022 Haybuster H1135 Tub Grinder (A55314)
2022 Haybuster...
2021 John Deere 333G Compact Track Loader, 390 Hours, High Flow Hydraulics, Ride Control (A57024)
2021 John Deere...
2011 Ford E-350 Passenger Van (A53422)
2011 Ford E-350...
2017 Nissan Versa SV Sedan (A55853)
2017 Nissan Versa...
2017 Ford Fusion Sedan (A55853)
2017 Ford Fusion...
