OIL QUESTION
   / OIL QUESTION #1
Tom Bacon
29hp TYM with Backhoe
I have a 29 HP TYM diesel Tractor with a backhoe.
Can I use Castrol Edge in this machine or should I use something else?
   / OIL QUESTION #3
How many hours on your machine? Also are you losing or leaking any oil? Synetics are well known for their cleaning abilities. Been using Mobil 1 5w50 since 50hrs. Would definitely check out Bob the Oil Guy website, plenty of serious oil experts there.
   / OIL QUESTION
Approaching 30 hrs, and I use Mobile 1 in my Explorer and plan on changing it to Castrol Edge as well. No sign of tractor leaks, but when I checked my hydraulic oil in the housing below the seat it, I could see no fluids so I filled it up. I thought I would change the engine oil shortly for it's first change and that brought up the type of oil question. When checking the Castrol Edge web page on the internet, some places note a yes on Diesel, and some ignore the question. Thus my confusion.
   / OIL QUESTION #6
Hello & WELCOME to TBN!
I moved your thread to the Oil, Fuel, & Lubricants Forum. :)
   / OIL QUESTION #7
Curious about your switching away from Mobile 1, ya mad at em or just too high priced? GRIN..
   / OIL QUESTION
Not mad, just believe the advertisement that Castrol Edge is 10 times better protection. If not true Mobil would have sued the pants off them
   / OIL QUESTION #9
No use something else, Edge is not a diesel rated oil i wont handle the soot and oil contamination produced by a diesel engine,stick with a diesel rated oil,CI-4 or CJ-4 spec oil.
   / OIL QUESTION #10
Correct:thumbsup:
You need a diesel rated oil.
Mobil Delvac
Shell Rotella
castrol tection or GTX diesel
Valvoline Premium Blue
Just to name a few
2012 Kia Sorento (A51694)
2012 Kia Sorento...
2016 Toro Groundsmaster 3505D 72in Rotary Mower (A51691)
2016 Toro...
GENIE MAN LIFT (A52472)
GENIE MAN LIFT...
2000 CATERPILLAR 140H MOTOR GRADER (A51406)
2000 CATERPILLAR...
2006 Volvo VNL (A52748)
2006 Volvo VNL...
2015 Crane Carrier Co. Low Entry (LE2/LD2/LW2/LT2/ST2/SD2) Truck (A51692)
2015 Crane Carrier...
