which rear blade to buy?
   / which rear blade to buy? #41
Brian, that is one beefy rear blade...I was interested in the Landpride 3584 in that it would have a hydraulic angle option but according to their spec sheet my 3320 would be underpowered for such a blade...according to their sheet the 2584 would be a better fit (but no hydraulic angling)
   / which rear blade to buy? #42
I'm assuming that you are talking about an RBT3584. In my opinion that is the perfect size blade for your tractor. When I can afford one that is the exact blade that I want to get :drool: to use behind my Mahindra 3215HST. My tractor weighs in right around 5000lbs. Your tractor with the loader weighs close to 4000lbs and with loaded tires you would be close to 5000lbs, plenty of traction and power to properly use that 700+lb blade. :thumbsup: How many remotes do you have? If you can come up with 4, that is just enough IMO. :D 1 for the angle of the blade, 1 for the offset of the boom, 1 for a hydraulic top link and 1 for a hydraulic side link. ;)
Good luck to both of us being able to get one of these blades soon. :cool2:
PALLET OF SCAFFOLDING PARTS (A52706)
PALLET OF...
2015 Ford F-350 4x4 Cab and Chassis Truck (A53422)
2015 Ford F-350...
2019 RAM 2500 Crew Cab Pickup Truck (A53422)
2019 RAM 2500 Crew...
2000 WINNEBAGO FORD F550 RV (A52472)
2000 WINNEBAGO...
2016 FORD EXPLORER (A51406)
2016 FORD EXPLORER...
2018 Ford Fusion Hybrid Sedan (A53424)
2018 Ford Fusion...
