tractor and mower attachment
   / tractor and mower attachment #11
In response to my problem concerning the brush hog and the pto on my Ford 800
series tractor. I have used these two items for years, the pto always had a bit of a
grinding sound when getting it to engage. You can even feel the roughness at times,
like the gears are hitting something. Anyway this tractor has live pto, it has five or
so speeds. I thought maybe the gear box may be low on gear oil, will check this out
this upcoming weekend. In the past I was able to spin the shaft manually. Last weekend
I tried spinning it again, and it would not move. I will have get down and check to
see if anything underneath may be preventing it to spin freely. This is an expensive
fix and I do not want to be taken advantage of. That is why I am inquiring why it
was working, then the next time I needed to use it, it would not work. Mother nature
has taken over huge areas where I use to keep the fields open with this equipment.
Now that I have this problem I am unable to mow those areas. So anyone with a
good idea, concrete or not, I am open for all the advice I can get, before I have to
resort to having my tractor hauled off to the repair shop.
if you have an 800 series that is a 5 speed and has live pto.. then it is an 860 and has a dual clutch in it.
If it s grinding to engage, the pto section may be stuck, or the freeplay adjustment is off, or there is simply enough wear in the system that the clutch is not fully disengaging.
if the pto section is stuck, it would prevent you from spinning the pto while it was engaged. if not engaged, and the pto won't spin, post back.
soundguy
   / tractor and mower attachment #12
...I apologize to everyone on this website...
Don't worry about the website... we worry more about the tractor.
Soundguy, can you go through what it takes to adjust the clutch??
   / tractor and mower attachment #13
external pedal freeplay adjustment is all you can really do on that ford double clutch...
soundguy
Re:Tractor and Mower Attachment
In reply to the pto. It does work. It engages.
Attach the brush hog and the difficulty begins immediately. It has gotten to
the point it will hardly engage anymore.
When the mower was attached last summer it would spin only momentarily
before it would make the tractor die.
In answer do I think I can follow instructions to attempt to adjust the pto?
Yes as long as they are clear step by step.
I do not want to harm the mechanism and make it worse is my main concern.
The weekend is near, and will be checking the gear oil level on the brush
hog, will also re-check to see if the brush hog will manuallyfree spin.
Somone had mentioned (locally) that this brush hog has a brake on it?
I was not aware that this model has a brake. It is a big woods brush
hog, you can remove the side plate, it has no shear pins.
Do all of you lean toward thinking that the pto will need to be replaced?
Well if I have overlooked any unanswered questions I again apologize.
I just need to solve this problem.
I thank all of you who have taken the time to respond to my e mails.
Respectfully
Mo(Maureen)
   / tractor and mower attachment #15
Attach the brush hog and the difficulty begins immediately. It has gotten to the point it will hardly engage anymore.
Respectfully
Mo(Maureen)
Hi Mo,
At this point, it really sounds like your 2-stage clutch is ready for replacement.
Soundguy is the resident expert on those old Fords...and I'm sure he'll chime in soon enough.
Now, when you drive your tractor, does the clutch slip at all? This should be more noticeable in the lower gears.
   / tractor and mower attachment #16
yep.. his main disc may be worn enough that he can no longer adequately clutch the pto section, assuming freeplay has been adjusted down to spec, or even a lil more so.
soundguy
   / tractor and mower attachment #17
   / tractor and mower attachment #18
...assuming freeplay has been adjusted down to spec...
How would one go about and check that out? I assume it's external? Set screw on the arm of the clutch? turn until tightens up and see if it works or if it still doesn't work? Got photos? She may not be the only one that could use the information... ;) Or is it a lot more to it?
   / tractor and mower attachment #19
simple rod and clevis adjustment. apparrent when you look at the clutch pedal linkage.. etc.
soundguy
   / tractor and mower attachment #20
To new members and old alike it sometimes helps to put your general location of where you are located in your profile because some members may read your posts and also be in the same area of the country and willing to come over to take a look and help you out. Just a thought I had!:D
Koyker Loader DoubleTine Bale Spear - Versatile for Round and Square Bales (A55301)
Koyker Loader...
2009 Ford F-350 4x4 Flatbed Truck (A51692)
2009 Ford F-350...
2007 Amkus Rescue System (A53421)
2007 Amkus Rescue...
2009 MACK GRANITE (A52472)
2009 MACK GRANITE...
2013 3400QB SUNDANCE 5TH WHEEL CAMPER (A52472)
2013 3400QB...
2013 BMW X5 xDrive50i AWD SUV (A53424)
2013 BMW X5...
