deck question
   / deck question
see what you mean about the steel. i guess when i start removing the floor which looks like my only option, i'll deal with joist support. i'll get someone to look at the span. thanks for all again.... looks like i have some work to do
steve
   / deck question #12
Carpet was a bad idea. But why is it getting so wet? How much roof overhang do you have?
   / deck question #13
steve
Not sure what your skill level is, but span tables are online. If you google "span tables joists headers" you'll find many. If you don't know how to use them post again, someone will help. It will be necessary to know the dimension from the wall to the end of the cantilever, the dimension from the wall to center of pier, and the distance between piers to figure out how much loading will be on that span. I'm guessing a W flange beam would easily handle that load in the space you have available.
   / deck question
the overhang doesn't cover all but most of the deck. if you notice in the photo the worst areas were exposed to the water-sun im guessing they covered it with carpet because they knew it was so bad underneath. beez thanks again and i'll take some measurments tomorrow. where can i get one of those w beams?
steve
   / deck question #15
thanks again, more to ponder. kinda knew about the span being questionable and was done along time ago so i'm not sure if actually up to snuff.
steve
Well if it is still structurally sound and it's been there for years, I don't think I would worry about the span unless you think the structural wood is rotted. If you go ripping out beams and posts it's going to cost a lot of money, so make darn sure that needs to be done first. The decking does not look that bad, hose it down with bleach ad see what it looks like with all the mold/mildew gone.
I think the biggest problem is not enough overhang(not much you can do about that), then the use of T&G that gets wet every time it rains. Hard to tell through pic's, but I am thinking remove the T&G, then re-deck with pressure treated leaving gaps for the water to go through & put in proper flashing at the sill.
   / deck question
have some measurements. the wall to end of deck is 122 1/2 inches-
wall to end of pier is 81 inches
pier spacing is 50 inches on first
105 inches on second
82 inches on third
86 inches on forth
how do these sound?
thanks
steve
   / deck question #17
82 inches on third
86 inches on forth
The 105" spacing controls the beam size, a lot depends on quality of lumber but you either need two 2x12s or three 2x10s, assuming I didn't make a mistake. That assumes 40psf live load, 10psf dead load. If you have lots of snow or a grand piano out there you should bump that up a little. So what's there is really undersized. It will take a little calculating to figure out what size steel beam is required. Even if I come up with a beam, I'd go pay a structural engineer for an hour of their time to do the calculation for you.
   / deck question
thanks beezfun! i will get an engineer to look at it. i think i've been lucky and i won't let anyone out there till it's fixed. to think i've had all the family out there for get togethers, gives me the chills.
steve
   / deck question #19
steve
An easy temporary fix would be to buy some shoring jacks at Menards and add them to the existing pier supports. I'd add two in the long span, one at midpoint on each of the other spans. They're probably only about $10-20 each.
It seems like the rest of that deck is pretty well built, those piers could hold up your house. Are you sure there isn't a piece of steel in there that isn't obvious, or some structural element that's not obvious in the pictures? For example is there a piece of steel between those two 2x4's laying down and that skirt board in front of them? It's surprising there isn't a lot of sag, especially in that long span. You might string line along the bottom of the beam and see how much it's deflected.
   / deck question
just checked for steel and i didn't see anything in there. i remember when we first bought the house about 11 years ago, it had a wrought iron railing. wife didn't like it so i removed it and had someone install the wood railing as it sits now. if i remember correctly i think the big span did have a couple of steel supports but he removed them for some reason. that wrought iron must have weighed a ton or more.
"the house that jack built"
steve
2018 HINO 338 KNUCKLE BOOM TRUCK (A51406)
2018 HINO 338...
2017 Chevrolet Silverado 2500 4x4 Crew Cab Pickup Truck (A55973)
2017 Chevrolet...
Kubota SVL95-2 High Flow Cab Skid Steer (A55302)
Kubota SVL95-2...
2022 Kubota LX2610SUHSD Compact Utility Tractor (A55315)
2022 Kubota...
2013 Chevrolet Silverado 1500 Ext. Cab Pickup Truck (A55973)
2013 Chevrolet...
Chevy caprice (A55758)
