So P.O.'ed I can't even see straight....
   / So P.O.'ed I can't even see straight.... #44
Had a similar situation. Went to HD and bought a VA screw extractor and yes it broke right off... What next.... I got out the OA cutting torch and hit it a couple quick times to burn the broken extractor out of the hole. Then I cut the end off a needle nose pliers and hammerd it into the burned out bolt hole. I twisted on it with a pair of vice grips. Came right out
After the VA screw extractor, I wanted something hard, but not as brittle. That is why I used the tip off the needle nose pliers.
   / So P.O.'ed I can't even see straight.... #45
...and Johnny Cash did the theme song.
Geez, let's not get this moved to a geezer thread.
Guys, I got a story to tell, but I apoligize for hi-jack of the thread. i saw the Op managed to get the broken part out. I know he feels better about that, now if he can find a grade 8 or higher replacement? I am going to Front Porch and start Geezer thread, Per sey.. :licking:
   / So P.O.'ed I can't even see straight.... #46
Yes indeed, F250DSLPWR had the audacity to get back on topic! Let's go somewhere where we can geez in peace.
Broken bolt was a Gr 8. (not 'great' and I now am wondering if it was one of those mis-marked made in china bolts??)
The part is only 90% out. The tip is at the bottom of the hole and resisting my attempts at getting it out. The silly carbide burrs are too short to reach it and nothing else makes an impression. That's why I have some 6" long burrs on the way.
   / So P.O.'ed I can't even see straight.... #48
FYI you can thank Irwin for destroying VA (and vise grips)
On the ez out. your doing the right thing. Not much can drill taps or ez outs other than carbide.
Personally i like the square ez outs.. i think there's a bit more meat on them (less likely to break) . It takes a delicate hand as you know.
Too late now, but there are special welding rods that can burn out taps. There are also rods that allow you to build up weld on a broken stud so you can weld on a nut. the special flux keeps the filler from plugging the threads in the bore.
In a rubber mount however your options involving heat might be limited.
   / So P.O.'ed I can't even see straight.... #49
Had to google "carbide burrs"
I have some of these I never knew they were carbide or what their name was.
Most likely they are all made in china now as well.
JB
   / So P.O.'ed I can't even see straight.... #50
JB
Cheap burrs yes. Good burrs no.
Much like drill bits it comes down to money. Spend some and you can get quality Made in US or europe.
2016 Nissan Pathfinder S SUV (A50324)
2016 Nissan...
2014 International WorkStar 7400 Truck, VIN # 1HTWGAAR9EH765325 (A51572)
2014 International...
New Skid Steer Attachment Plate (A53002)
New Skid Steer...
New/Unused Quick Attach Post Driver (A51573)
New/Unused Quick...
JOHN DEERE 54D LOT NUMBER 160 (A53084)
JOHN DEERE 54D LOT...
