Antifreeze change on my GC
   / Antifreeze change on my GC
No, what did you use?
It is the factory fill that I changed. Only 87 hours on it. I did the water flush and used the Fleetguard myself. I did not notice the gelling anywhere but in the overflow jug and on the tube. I should have took a pic and posted, but didn't think much of it at the time. I will keep an eye on the fleet guard. I did notice that the factory antifreeze was very green, almost like full strength? Didn't test it, just took for granted that they surely made sure it was right:ashamed:eek:ops!
   / Antifreeze change on my GC #12
The OEM product was some sort of proprietary product, that's why it had a strange look to it.
Before the days of Dexcool, all antifreeze, (for gas engines),was equal. Now, just about every manufacturer has a "special" factory fill. Some required it used for warranty purposes. The last time I checked at the body shop, we had like 6 different kinds of antifreeze for different manufacturers. Each one seemed to have it's own particular color.
As stated, I used the Fleetgaurd. I did not flush it beyond filling it with water once, and pulling the lower hose off. And I have not noticed any gelling.
   / Antifreeze change on my GC #13
When Pat (tech) came to our house to install the block heater, he bought Car Quest low silicate diesel anti freeze, green stuff. I am thinking MF (Iseki) uses nothing special in this case, even if MF spec'd.
   / Antifreeze change on my GC #14
Look, after 32 years servicing vehicles, I know what common antifreeze "normally" looks like. It may not, and should not, be anything special, because they do not specify it to be anything "special". BUT, the factory fill is NOT a "common" off the shelf antifreeze, as Wacky noted, it has a different color to it. This is usually how you identify your product if you are producing a proprietary product. And, this is definitely someones proprietary product.
   / Antifreeze change on my GC #15
I was pointing out my experience. No need to get touchy.
The antifreeze in the 1635 is no proprietary product, off the shelf green stuff, and no need to run the MF stuff, unless clearly specified. Just has to be low silicate. Remember Magnusson Moss??
   / Antifreeze change on my GC #16
No. How many hours on it?? Going to change mine out soon, to Cat ELC. (PDF here.) Good for 3,000 hours out of the jug, and can go 6,000 with an additive. Will be using pre-mix, and just a water flush.
You might want to check with the OEM and MAKE sure the gaskets & seals can stand up to any brand of ELC.
The Cat DEAC might be a better choice. That,s whats going into my Boomer when I change it.
Cat Coolant Lowers Maintenance Costs & Provides Advanced Metal Protection
My opinion, if it's got green in it, put green back in it. Unless your sure it can stand ELC,
   / Antifreeze change on my GC #17
Great, except you have a completely different tractor.
Since you seem to need to comment on every post I make lately, there was a need.
No one said anyone should, or needs to run MF coolant.
I am not sure where you would get antifreeze that is not low silicate anymore, with all the aluminum engines out there today. And in fact, our book does not even bother to specify low silicate, probably for that reason.
I don't see how this is relevant, since again, no one said anyone had to run MF.
   / Antifreeze change on my GC #18
   / Antifreeze change on my GC #20
6000 hrs with the additive? That is the lifetime for majority of tractors out there. I would never trust a manufactures claims until years go by and a track record is established. The AF may last that long but how do you know a key ingrediant is lacking/used up over the years without laboratory testing??
I have seen too many claims for wonder products out there over the years and many after years of use do not perform as claimed.
Antifreeze is cheap. I change mine very 1.5-2 years. Takes around one gallon for my tractor-that $11-12 ever 2 years. Cheap insurance.
Everyone should be using distilled water also and not tap water.
CASE INTERNATIONAL 5140 TRACTOR (A52707)
CASE INTERNATIONAL...
2014 Jeep Grand Cherokee (A56859)
2014 Jeep Grand...
Hyster H90FT 8,000lb Diesel Forklift (A55973)
Hyster H90FT...
12 X 20 CAR PORT (A58214)
12 X 20 CAR PORT...
2018 Ariens Ikon 52in Zero Turn Commercial Mower (A56857)
2018 Ariens Ikon...
2017 JLG Skytrak 6036 6,000lbs 4x4 Rough Terrain Telehandler (A56857)
2017 JLG Skytrak...
