Outdoor Kitchen
   / Outdoor Kitchen
Couple more pics of the framing.
   / Outdoor Kitchen
Whoops, here they are.
   / Outdoor Kitchen #83
Coming right along Buggyman! Did you buy the angle grinder polishing set up for your counter tops? I had thought about doing concrete, but I'm not sure now. We saw granite for $39/sqft installed and may go that way. Looks good so far, thanks for the update.
Mark
   / Outdoor Kitchen #84
One more question: What kind of grill did you get? Looks pretty nice, but you may want to consider using metal framing around it. Just a suggestion, they get pretty hot.
   / Outdoor Kitchen
Mark
I'm using my random orbit sander with the diamond pads and water.
   / Outdoor Kitchen
The grill came from lowes, not sure of the brand. I couldn't justify paying 3 or 4 grand for the grill.
   / Outdoor Kitchen #87
looks pretty darn good. have to let us all know how much work the concrete counter tops take for final sanding & sealing... I am thinking of going the same way my lowes and Menards carry the quickcrete counter top stuff. wasnt sure best way to try and get mine up stairs though... thinking have to pour them almost in-place or at least pour them in the 2nd floor room then flip em over like yours are. would be nearly impossible to move them up the stairs and probably just as much as flipping them over without pouring them in-place.
How would that work??? have to finish trowel the top surface to smooth then sand to finish? never done it myself but the build of this place has been a full series of never done it before ...
got my floor finished
little too wet here in ohio to get much done floor waited 40 days to stain then over 2 weeks after staining to seal and still floor has some blushing in the sealer and some spots that didnt stain well or stick well due to moisture I think..
mark
   / Outdoor Kitchen
mark
It is a messy process, it could be done indoors but you would have to cover everything. I used liquid color and mixed it in when mixing the concrete, just pour it in the water. Sanding is also messy as you have to use water, and sanding the slurry will be worse. I don't think pouring in place you could get it as smooth as using the upside down method, it really comes out almost perfect.
   / Outdoor Kitchen
To give everyone an idea of how heavy they are: The lower one in the picture measures 861/2" x 26" x 2" We used 5, 80lb bags of concrete, a gallon and 1/2 of water per bag, plus the rebar. Not sure what happens to the water in the chemical process as far as weight goes. I'm guessing it weighs around 425lbs at least.
Adams Tender / Magnolia Trailer (A53473)
Adams Tender /...
City of Buckhannon -Onan 50 Set Stand By Generator (A52384)
City of Buckhannon...
2003 Ferris IS1000 52in Zero Turn Mower (A51691)
2003 Ferris IS1000...
2008 Ford F-450 SD 4WD Pickup Truck (A53117)
2008 Ford F-450 SD...
2001 Blue Bird Commercial Portable Office Bus (A51692)
2001 Blue Bird...
1995 Mazak VTC-16B Vertical Traveling Column Machining Center (A51691)
1995 Mazak VTC-16B...
