Dessicant Water Filters
   / Dessicant Water Filters
That's good info.. Thanks Colin :thumbsup:
   / Dessicant Water Filters #12
It could be a different desiccant; there are many. Calcium sulfate is a good one. It can be regenerated at around 200-250 C I think, or around 450 F. You can buy it with a built-in indicator (cobalt chloride, in case you're interested...) that is blue when the desiccant is dry and pink when it needs to be regenerated.
DRIERITE is a well-known vendor of the stuff. It's pretty cheap, and it can be used over and over again.
Thanks, looks like $90 for 10 lbs. so I will use what I have. There is an indicator on the tank.
I really don't do very much automotive painting anymore, so it is not that important now.
   / Dessicant Water Filters #13
Incidentally, gypsum is calcium sulfate hydrate. I bet you could crumble up some drywall, dry it off in your oven, and use that. You'd need to make sure the powder didn't get into your air lines, naturally.
Plaster of Paris is also calcium sulfate with a different degree of hydration. That should also work if you bake it in your oven at 450 F or so.
Well, I looked at the indicator tonight and it was blue.. maybe I shouldn't check it right after welding a bunch.. :laughing:
   / Dessicant Water Filters #15
Well, I looked at the indicator tonight and it was blue.... :laughing:
I am not sure..but i think that means that your pregnant?? :laughing:
   / Dessicant Water Filters #16
Gaining dust to get rid of water is not a good trade.
It is hard enough to keep the desiccant dust from from accumulating in one of these filters, if you change it regularly.
   / Dessicant Water Filters #17
Agreed. Maybe that's why Jake's filter has silica gel as a desiccant. I would think that it's less likely to turn into powder than calcium sulfate.
1453 (A57192)
1453 (A57192)
2004 TRAVIS BODY & TRAILER ALUMINUM BELLY DUMP (A58214)
2004 TRAVIS BODY &...
2017 JOHN DEERE 323E SKID STEER (A60429)
2017 JOHN DEERE...
2017 Ford F-550 4x4 Dur-A-Lift DTAXS39 39ft. Bucket Truck (A60460)
2017 Ford F-550...
2012 Vermeer V500LEHD Vacuum T/A Towable Trailer (A55973)
2012 Vermeer...
1995 Rinker Captiva 190 (A56438)
1995 Rinker...
