Hey Pack!
Started this out by sharing photos of my spray can paint experiment in posts #22, 23, & 24 in the following:http://www.tractorbynet.com/forums/kioti-owning-operating/220815-rattle-can-paint-closest-kioti.html. Since I managed to bust the lower plastic grill on my DK late this summer (debris going thru the opening in the grill guard), I've decided to add some heavy duty expanded metal to the outside to prevent this from happening again!
(This is not the thin grade of metal that you get at Lowes, HD, or TSC. I got this at a metal supply shop. This is the grade metal they use on utility trailers...I'll see I can find the receipt that lists the grade or size. It was a 1/4 sheet for about $22.)
BTW, I almost punctured my battery!!!
Here are some photos of my progress to date as I hope to finish up this weekend. I promise to post pics as I attach it and paint it. Also, if 4Shorts is reading this, you are so talented and watching your work thru your posts has been very inspiring! I plan to immitate your work as close as possible.:thumbsup:
The first 4 pics show the "basic" layout following the frame and what it looks like cut out. The remaining pics show it in position. As you can see, I'll have to trim it up a little and I do plan to follow the contour towards the bottom. Stay tuned.....
