Bad hydo pump on my 2310! HELP!
   / Bad hydo pump on my 2310! HELP! #1
Aaron hoedown
Massy 2310 TLB
Bought my 2310 brand new in '05. its ran perfect with no problems, until the hydraulic pump died. I used this forum to try and figure out the problem? I came across a few posts on bad pumps in these earlier machines. Sure enough (after arguing with the service guy) it turned out to be that I got "short shafted", or the input shaft on the pump was not designed well enough, and didn't engage the female part deep enough. After they fixed it, and I payed for the repair ($2000), I tried to get a goodwill warranty from Massey. They offered to pay HALF OF THEIR COST!! Or $180. Now. I know I'm out off warranty BUT IT ONLY HAS 455hours! It is a bad design(they know about it AND have redesigned it!)
Can anybody help me or give me some advice please?:(
   / Bad hydo pump on my 2310! HELP! #2
I am not sure what we can do for you other then tell you some of us are in the same boat.
I agree they should have recalled these, and made the proper repair. But they clearly have decided not to.
What the rest of us need to know, is if we should replace the pump preemptively? :confused:
   / Bad hydo pump on my 2310! HELP! #3
Sorry to hear that, keep trying-usually out of warranty repairs on any thing only results in the manufacturer paying for just the parts-labor is always the most expensive of the bill. the good news is it's still better\cheaper than buying a new tractor.
   / Bad hydo pump on my 2310! HELP! #4
Would you happen to have the part numbers on the failed and the replacement pumps? I'm at approximately the same number of hours. I'm considering replacing mine preemptively rather than have it fail 1/4 mile into the woods in January.
   / Bad hydo pump on my 2310! HELP! #5
Today, for the second time I went to use my Massey 2310 and it moves back and forth but no hydraulics anywhere. The first time was covered by warranty. They said the splines on the shaft were too short. Thought that the problem was solved, but I guess not.
Any help would be appreciated.
   / Bad hydo pump on my 2310! HELP! #6
Check all of your quick connections you may have a connection that looks good but not completely connected and causing a blockage not allowing the hyd. to work. Been there done that.
Doug
   / Bad hydo pump on my 2310! HELP! #7
Thanks for the suggestion Doug. I did try this, but was not the problem. Will keep trying...appreciated.
   / Bad hydo pump on my 2310! HELP! #8
If the pump fails,,,,you still can drive it??:confused:
   / Bad hydo pump on my 2310! HELP! #9
Have you met with the regional rep?
You could always write a letter to MF and ask to speak with the CEO. You may get someone to help. Just some ideas. I hope the best for you.
   / Bad hydo pump on my 2310! HELP! #10
Sorry to hear that, keep trying-usually out of warranty repairs on any thing only results in the manufacturer paying for just the parts-labor is always the most expensive of the bill. the good news is it's still bettercheaper than buying a new tractor.
True.....but still not right.
1998 INTERNATIONAL 9400 (A58214)
1998 INTERNATIONAL...
2012 DOOSAN G25KW GENERATOR (A55745)
2012 DOOSAN G25KW...
CONCORD CRE96018B CONVEYOR BELT (A52706)
CONCORD CRE96018B...
PALLET OF 12IRON GATES (A58214)
PALLET OF 12IRON...
25ft Tag Trailer (A56435)
25ft Tag Trailer...
flooring (A55758)
flooring (A55758)
