New 4000 series JD same cu in engine
   / New 4000 series JD same cu in engine #11
The old Alis Chalmers C model short block was made by Morris Garage (MG).
   / New 4000 series JD same cu in engine #12
I think a lot of you guys are way underestimating development and manufacturing costs. Remember, even reprogramming a chip requires testing (for effectiveness, durability and emissions), none of which is cheap to do.
And things such as injection molded plastics...how much do you think those mold tools cost? It's easy to spend $250,000.00 on tooling and those costs have to be amortized. Then you have overhead costs (shipping, distribution, advertising, etc.).
This isn't some Mom and Pop shop work, or some computer whiz working in his basement office deveoping this kind of stuff...
   / New 4000 series JD same cu in engine #13
Something else everyone is forgetting - each larger model comes standard with larger sized tires and wheels to be able to transfer the extra power to the ground. If you have ever priced new wheels and tires, that's not a cheap upgrade.
Sorry JD110 all of the top four tractors have the same tires and rims. Front are 8.00 X 16 and the rear are 13.6 X 28
   / New 4000 series JD same cu in engine #15
I have any early 4120 (2005 I think built in 2004) I have had several service trip with my JDDealer and the last trip in they had to run it on their dyno. The PTO rated horsepower on mine is listed as 35. The dealer stated in my service comments that my tractor was putting out 46 horsepower . Since they did adjustments to my tractor I noticed considerable amount of power increase .
   / New 4000 series JD same cu in engine #16
20 hp change and running same clutch? Gears? Pumps? Radiator? Same weight? I know changing turbo sizes isn' cheap. Just some ideas to consider. And like mentioned, every configuration gets tested and rated.
2003 CATERPILLAR D6R XW HI-TRACK CRAWLER DOZER (A51406)
2003 CATERPILLAR...
UNUSED 20PCS Industrial Polyester Lifting Straps (A53117)
UNUSED 20PCS...
2011 Kenworth T300 Jerr-Dan 21WSRB Rollback Truck (A52377)
2011 Kenworth T300...
UNUSED RAYTREE RMBD50 - 50" DRUM MULCHER (A54757)
UNUSED RAYTREE...
UNUSED IRANCH IRGC40 HIGH END MINI GOLFCART (A54757)
UNUSED IRANCH...
2018 WACKER NEUSON RTSC3 ROLLER (A52576)
2018 WACKER NEUSON...
