Home made log skidding attachment
   / Home made log skidding attachment #11
i had an incident this weekend, when i was skidding logs i went up a small hill and the tractor weels come up 1 foot and stayed up till i leveld out, i then added more weight to front it helped a little,from now on i will cut the logs smaller.
In the video they don't show it, but there'a a pull chain attached low in the still picture.
They lift from the log hog but pull from a lower spot on the tractor (draw plate?)
Maybe you are looking at a different still photo than I found. I used the zoom feature on the still from Northern Tool's web page and couldn't see the pull chain you refer to. I also looked on Norwood's website and couldn't find it there either.
Regardless, it does sound like a good idea to add the pull chain if I'm pulling a heavy log. Thanks for the suggestion.
When those wheels come up is the time to either kick the clutch in or come off the HST pedal in a hurry. In your case, it sounds like the forces did balance, but pulling with the front wheels off the ground is more than a little bit hairy!
Carry-On 5'x8' Trailer (A53316)
Carry-On 5'x8'...
New Wolverine Sid Steer 3PT Hitch Quick Connect (A59000)
New Wolverine Sid...
Kubota HB84 Hopper Broom (A53317)
Kubota HB84 Hopper...
LOT: Air Hose Reels, 220 V Cord, Electrical Cords, Hand Tools, 2-Wheel Hand Truck (A59076)
LOT: Air Hose...
2022 Ford F-150 XL Pickup Truck, VIN: 1FTFX1E88NFB23656, Extended Cab, 4 x 4, 3.5 L EcoBoost Gas (A59076)
2022 Ford F-150 XL...
2019 International Bucket Truck (A55973)
2019 International...
