Home made log skidding attachment
   / Home made log skidding attachment #11
i had an incident this weekend, when i was skidding logs i went up a small hill and the tractor weels come up 1 foot and stayed up till i leveld out, i then added more weight to front it helped a little,from now on i will cut the logs smaller.
In the video they don't show it, but there'a a pull chain attached low in the still picture.
They lift from the log hog but pull from a lower spot on the tractor (draw plate?)
Maybe you are looking at a different still photo than I found. I used the zoom feature on the still from Northern Tool's web page and couldn't see the pull chain you refer to. I also looked on Norwood's website and couldn't find it there either.
Regardless, it does sound like a good idea to add the pull chain if I'm pulling a heavy log. Thanks for the suggestion.
When those wheels come up is the time to either kick the clutch in or come off the HST pedal in a hurry. In your case, it sounds like the forces did balance, but pulling with the front wheels off the ground is more than a little bit hairy!
2006 Hyundai HL740-7 Articulated Wheel Loader (A56857)
2006 Hyundai...
SD Launch SDLB25 (A53317)
SD Launch SDLB25...
2015 GMC 3500 HD 4x4 Crew Cab Pickup Truck (A55973)
2015 GMC 3500 HD...
2015 Kenworth T880 QMC 8060R 40 Ton Tri Axle Crane Truck (A55973)
2015 Kenworth T880...
2015 Nissan Rogue SUV (A56859)
2015 Nissan Rogue...
UNUSED AGT SSPOC HYD LOG GRABBER (A52706)
UNUSED AGT SSPOC...
