JD auto-connect mowing decks
   / JD auto-connect mowing decks #11
Now I am trying to figure out whether to go for a 2720 over a 2320. I like the larger tires and the added horsepower, but don't like the added cost.
Well,there is that one model in between those two. The 2520.:thumbsup:
Not that I'm partial to that one or anything.:D
Greg
   / JD auto-connect mowing decks #12
Thanks for all the posts! I went to UTube and watched videos showing how to attach and detach the 62D deck on the JD2320. Wow, it took only about 2 minutes each way. I think the drive-over deck is a big plus and goes a long ways to making the attachment process painless. I'm ready to resume looking at the 2000 series tractors.
Now I am trying to figure out whether to go for a 2720 over a 2320. I like the larger tires and the added horsepower, but don't like the added cost. Guess you get what you pay for.
I have a favorite quote about horsepower:
"Better to have it and not need it, than need it and not have it....."
   / JD auto-connect mowing decks #13
that must be one heavy duty deck to withstand the stresses of running over it to attach it
   / JD auto-connect mowing decks #15
True... I was one of the fortunate ones that got a 2520 with the $2500 rebate... also got the 200CX FEL, 62d and 54" snow blower... I am happy as a clam. All for $20,300.... The 2520 has the beefier drive train and other parts as well. Well worth the money... I was also told JD is going much cheaper and using parts that they use in the models they sell to HD and Lowes. Buyer beware..
   / JD auto-connect mowing decks #16
Having just bought a 1023E with the 60D AutoConnect deck... I don't know that it is worth all the hype. It is wicked cool - BUT you need to be PERFECTLY lined up and be on the right type of ground in order for it to work properly. Maybe I haven't had enought practice... Only hooked/unhooked it half a dozen times or so and it takes me a good 10 minutes to get it right
Hi Guys
Thought I'd chime in on the auto-connect 60D. I have it on my 1026R and with a small modification to the locking bar and spring mechanism, it takes about 30 seconds to connect and go! Driving over the deck is the longest portion of the exercise.
I noticed several members commented on the spring for the lock mechanism not being strong enough to actuate. Initially mine was too until I took the locking rod assembly off and noticed the dimensions are not quite right. With a couple well spaced washers to "unload" the compression being induced, it works perfect!
I also have experimented with tolerance for line up during hookup and found you can be considerably off and it will still go on fine. At least 3/4" either side as the chine on the lock slides will position for you. Having the PTO selected to rear also seems to help!
Cheers
   / JD auto-connect mowing decks #17
I recently purchased a JD1023E with auto-connect 54" deck. I had my doubts about getting the auto-connect version. The dealer had not sold one for any of his JD models. However, he said if I went with it and didn't like it he would exchange it for the standard deck. How could I lose on that offer. So far I'm thrilled with it. I timed it and it took 35 seconds to connect. I haven't had any alignment issues with it yet. I did several removals and installs to show off to my friends. At first I had a problem with the rear latches not setting but that was solved with a little grease. I think I'm really going to like this feature so I can easily remove the deck and clean it regularly. Something I couldn't do with my previous tractor (at least not easily).
   / JD auto-connect mowing decks #18
Purchased a 1026R with auto connect 60D mower Deck. It easily connects and disconnets. When I engage the blades there is a definate rattle, then goes away as I increase speed. Dealer says this is typical. Has anypne experienced the same thing?
   / JD auto-connect mowing decks #19
I noticed the same and put it down to resonance frequency and have also heard similar with other attachments. Its not uncommon with anything that produces frequencies and usually dissipates with RPM changes....IMHO!
   / JD auto-connect mowing decks #20
I have the same tractor and deck. I noticed mine was rattling when I first started mowing. I looked at my pto selector and it was on mid/rear. I put it on mid only and a lot of the rattling went away. I think I was too excited to start mowing when I got it and I overlooked this.
KUBOTA SVL-75 SKIDSTEER (A52472)
KUBOTA SVL-75...
MANLIFT (A52472)
MANLIFT (A52472)
2018 CHEVROLET 1500 SINGLE CAB TRUCK (A51406)
2018 CHEVROLET...
AIRMAN POS100S PORTABLE AIR COMPRESSOR (A52472)
AIRMAN POS100S...
Electric Mobility Scooter (A51694)
Electric Mobility...
2022 Ford Maverick Crew Cab AWD Pickup Truck (A50323)
2022 Ford Maverick...
