PamlicoLawnCare
- Joined
 - Oct 19, 2011
- Messages
 - 7
This is my first post although I have been loitering on a daily basis for several months now.
Ford 2000 Model Number: 21201
Ford 2000 Serial Number: <> 4162 <>
Below I have cut and pasted the codes for the numbers.
Thousand Series tractor serial numbers -
1962 Serial number 1001 - 11947
1963 Serial number 11948 - 38930
1964 Serial number 38931 - up
Decoding the 5 digit model numbers on 2000-4000 series tractors -
First number (1 digit)
2**** - 134 ci gasoline or 144 ci diesel engine
4**** - 172 ci gas, LP-gas or 172 ci diesel engine
Second number (1 digit)
*0*** - Industrial models produced prior to 1963
*1*** - Industrial and agricultural models produced after 1963
Third number (2 digits)
**10 * - Row crop
**11 * - Offset
**20 * - Utility-type w/adjustable front axle
**21 * - Orchard type w/ non-adjustable front axle
**30 * - Utility-type tractor w/non-adjustable front axle (light industrial)
**31 * - Low center of gravity (LCG tractor)
**40 * - Heavy duty industrial tractor w/sub frame
**41 * - Heavy duty industrial tractor w/sub frame & cast grille
Last number (1 digit)
*1**0 - Four-speed w/o PTO
*0**1 - Four-speed w/o PTO or hydraulics
*1**1 - Four-speed w/PTO
*0**2 - Four-speed w/hydraulics, w/o PTO
*1**2 - Five-speed w/live PTO
*0**3 - Four-speed w/hydraulics and PTO
*0**4 - Select-O-Speed w/o hydraulics or PTO
*1**4 - Select-O-Speed w/o PTO
*0**5 - Select-O-Speed w/hydraulics and single-speed (540 rpm) PTO
*0**6 - Select-O-Speed w/hydraulics, 540 and 1000 rpm PTO and ground-speed PTO
*1**6 - Select-O-Speed w/two-speed (540 and 1000 rpm) independent PTO
*1**7 - Select-O-Speed w/540 and 1000 rpm independent PTO and ground-speed PTO
*0**9 - Five-speed w/live PTO
The serial number (4162) designates the tractor is a 1962.
The second digit (1) in the model number (21201) designates the tractor was produced in 1963.
This seems like a contradiction.
Why is the tractor considered a 1962 model if it was produced in 1963?
I actually thought I may have initially misread or miswrote the numbers wrong so I drive 30 miles roundtrip again to verify that the numbers were correct.
Any help or explanation would be appreciated.
Thank You,
Rod Jordan
Pamlico Lawn Care, LLC
Oriental, NC
**10 * - Row crop
**11 * - Offset
Thank You,
Rod Jordan
Oriental, NC
