New Tractor owner with a not so new tractor
   / New Tractor owner with a not so new tractor
Yes George you are correct! Ive been eyeing up a 45 gallon steel drum I'm going to fill with scrap steel and cement and make an attachment for the 3 point hitch. Also thinking about using antifreeze in the tires since I can get it really cheap. Does anyone know what ratio antifreeze to water? I know not to fill them up more than 3/4 full. Do I need to buy the pump or is there another way of doing it?
The first tire is the tire I would like to go with but I don't think they make it in my size. Can't find it anyway. It looks like it would be really good in the snow. More than likely I'm going to get the same ones that are on the tractor now which are the second ones. I had searched which is the best tire to use in the snow and think I am more confused now than I was before! I think down the road I would like to get some AG's or maybe R1,2 or 3's. Does anyone know what size rims I should start looking for?
Thanks Chris
   / New Tractor owner with a not so new tractor #13
Thanks Chris
Just remember, with a 4WD tractor, you must keep the circumference ratio between the front and rears tires correct.
That may limit your options for replacing the rear tires.
Sounds like #2 is a winner!!! I saw them in 8 ply rated at Maximum Load: 3430 lbs @ 45psi and also 4 ply but not sure what they are rated at. I would like to get the 4 ply cuz there half the price but then I would imagine I could only put half the weight on them. The tractor is about 1500 lbs without the FEL and ballast. What are your thoughts on that?
Thanks
Chris
   / New Tractor owner with a not so new tractor #15
As long as you work within the loader and 3PH specs, I think you'll be fine with those 4 ply tires...
Like any turf tires, these won't be as puncture resistant as Ag or Industrials. That may be a problem if you intend to work in the woods for your firewood.
BTW, you wrote in your original post about clearing snow in your mother's upstate NY home. Are you close to her, or do you have to transport your tractor?
Since it looks like you've decided on the tires, I suggest you consider chains very soon. Won't be long before you start seeing the white stuff...
   / New Tractor owner with a not so new tractor #16
You mentioned filing a 45 Gall drum with concrete and steel. I think that might be overkill and you will have too much weight on the back and will lose much traction on the front tires when the loader is empty. My guess is about 400-500 lbs of ballast on the hitch should be adequate. I think the 1200 hrs is not so bad. The local dealer was asking about $4500 for a B7500 with 2100hrs a few years ago. That tractor looked rather rough but it worked and was sold eventually.
I second the opinion that you will be fine with the 4ply tires. I had 4ply turfs on my previous tractor and no issues. Just keep it up to proper pressure (22psi front 16 psi rear on my previous tractor if memory serves right)
Another thing. Turf will not require a very fancy and expensive set of chains. I bought the cheapest ones available and hauled firewood in 10-12" of snow.
   / New Tractor owner with a not so new tractor #17
That would be a good starting point...easy to add more weight.
I use 4-link ladder chains and they work good for me. Figure about $190 for the chains, plus shipping. I'd try just chaining the rears initially.
   / New Tractor owner with a not so new tractor #18
The first tire is a bar-turf tire, just got on my B2920, AND my first tractor, a B1750 had them and they were great in the snow, better than R4, check the B2X20 models because you can get the bar turfs on them, when I get home I will check size and manufacturer.
   / New Tractor owner with a not so new tractor #19
that looks a little hairy. more so that 3rd picture! be careful! if you are a welder. then perhaps a couple pole holders on top side of bucket. that you could latch a couple good size metal poles into. when moving the fire wood. if you need to lift stuff that high. but even then. *cringes* a slight move and you could be dead.
if you are a DIY'er and seems like ya got descent knowledge to do maintance work. keep it.
on other hand. with all the logs and like you are dealing with. in a few years. you might consider looking at a TLB (tractor loader backhoe) the backhoe might make moving logs here and there easier. more so if backhoe had a thumb on it. though backhoe and thumb at times doubles the cost of the machine.
you might also consider a grabel to go with bucket, or remove bucket and go with some forks on the front. if you keep the logs long enough. it can make it easier to get the forks to slide up under a log.
i didn't see any work lights. front or rear. you might want to double check your alternator size, to see if it can handle 30watt hallogen work lights or 55 watt hollagen work lights. or if you need to go with LED work lights.
other misc things would be a tool box. and place to hold chains on the tractor. perhaps a spot to hold a couple 5 gallon buckets with tools in them.
*shrugs* above just kinda what i tend to see more folks do once they get inital tractor. regardless if used or new. and use what every they can find that works for them and majorty of there planned projects.
as far as tire pricing. it takes some calling if you start calling tire places up in phone book. same thing on internet. but if you keep trying and calling up to places 2 hours away from you. prices can change quickly. and that is including travel for me. it was actually cheaper to get someone almost 2.5 hours away. to come show up, pull old tires off, and put new ones on. plus i got a higher ply rating ((needed it to deal with thorn bushes, and other rough material i would more likely encounter)) and was still 200 bucks cheaper that most other places around me. and same manufacture tire.
also note there are a variety of tire manufacturers. your best bet to find tire places online would be try searching for "ag tires" or "r1 tire" or "r4 tire" and then once on agriculture / tractor tire website, look up turf tires for your machine.
also see about costs for adding a liquid into the rear tires. for extra rear ballast.
the tires i recently got it was only a few more bucks to get tubes bought and installed at same time. ya most likely not really worth it. but *shrugs* any extra rubber a blasted thorn has to go through to puncture hole in my tire is plus for me.
I'm looking at buying a 16 foot equipment trailer from a guy from my job for $1000. He has the trailer registed at 10,000 pounds which I know is way overkill but I'm gonna be using it to haul my logs as well.
You mentioned filing a 45 Gall drum with concrete and steel. I think that might be overkill and you will have too much weight on the back and will lose much traction on the front tires when the loader is empty. My guess is about 400-500 lbs of ballast on the hitch should be adequate. I think the 1200 hrs is not so bad. The local dealer was asking about $4500 for a B7500 with 2100hrs a few years ago. That tractor looked rather rough but it worked and was sold.
I have to look for the picture of the one I want to wanna make a copy of but I was gonna make it 400 pounds.
Thanks now I have to get a backhoe!!! :D I dont need to lift it that high yet. I did that for the picture. I had picked up a millermatic 211 a few months ago and haven't had time to play with it yet. I had a bunch of ideas for the bucket but I like the idea of putting posts on it to stop logs from rolling back. I need some chain hooks a class three hitch. I was even thinking of fabing up a grapple. I think I need a bigger bucket! I saw a lot of good ideas on this website. I was also planing on changing the tires myself. I've always done my dirt bikes and quad tires myself and built up a nice collection of nice size tire irons. If not I have a harbor freight around the block from my house they have I think it was a 3 foot long tire iron. Do I need to use tubes with antifreeze?
2015 Hyundai Veloster Hatchback (A53424)
2015 Hyundai...
Freightliner Tender Truck - Adams Tender (A53473)
Freightliner...
2020 CHEVROLET 2500HD CREW CAB TRUCK (A51406)
2020 CHEVROLET...
2012 BIG LOW BOY 130BBL VACUUM TRAILER (A53843)
2012 BIG LOW BOY...
2009 KUBOTA M7040 TRACTOR (A51406)
2009 KUBOTA M7040...
2009 Hino 268 Progress VTA72 1500 Gallon Vacuum Truck (A51692)
2009 Hino 268...
