High Tension power lines
   / High Tension power lines #31
I am sure this could be different in other areas. The way it was explained to me by the power company where we live is that we still owned the land but by accepting the cash settlement for the easement we had to abide by their stipulations on the restrictions of the easement. It was our land but the power company had total control of how this easement was to be used. I never really felt that this was our land after the easement went through. I guess its all in how a person perceives ownership.
   / High Tension power lines #32
Perhaps you've already done this, and if so, my compliments for your wisdom, and you can disregard the rest of this. If not, or to anyone in similar circumstances, my suggestion is to get with a good attorney who specializes in zoning/development laws in your county. You first need to know if you can even get a building permit for that property.
The reason I suggest this is that if the price is well below market value, it may be for a reason you are not aware of. For example, your county may now have minimum road frontage requirements in order to get a building permit. Or they may require more acres than the size of the property you're considering. These are just a couple of things that could stop you from building.
If it sounds too good to be true, there may be a reason. Good attorneys are not cheap, but they are well worth it if it keeps you from making an expensive
mistake. Good luck!
GGB
   / High Tension power lines #33
I hear the new strains of Roundup ready alfalfa do really well under high voltage transmission lines. The hybrid is stimulated by the electricity.:laughing:
   / High Tension power lines #34
I grew up under some 69,000 Volt lines and there is nothing ,nothing ,nothing, nothing, nothing wrong with me!;)
James K0UA
   / High Tension power lines #35
In many states there are differences between easements, rights of way and servitudes and they are defined different ways in different jurisdictions.
On my property, the power lines are on a 150' easement, the railroad tracks are on a 200' right of way and I have a 10' drainage servitude on the rear of my property. If I ask 10 different people what the difference is, I will get 10 different answers. :confused2:
   / High Tension power lines #36
In my deed, a timber company has the rights to drive horse teams across my land. It has been there since the late 1800's. But no mineral rights, but nothing down there.
   / High Tension power lines #37
KOUA,
Is that evaluation of having nothing wrong with you, nothing! nothing! nothing! your evaluation or is it the confirmed feeling of medical professionals? (Laughing!) Living your life under 69,000 volts is something that few of us experience. By they way, my comment is entirely in jest and I presume your personal evaluation of nothing wrong is probably right on.
Years ago I made hay on a 35 acre piece of ground on which we farmed directly below some very high voltage lines, I don't know what the voltage was, but the wires were suspended in three sets of three wires each that were also separated from each other by a triangular device that provided approx. 3 ft of separation between the three wires suspended on each of three support arms on each tower. There were two rows of towers set side by side. To the best of my knowledge, these transmission lines were part of the main north south inter tie system between Bonneville Power from the dams on the Columbia River and a connection that fed into California.
I was told that depending on the season of the year and the time of day power was routed over these lines north or south to provide energy as the demand changed in any given area, air conditioning versus heating often being the determining factor.
When working directly below the lines they were usually silent and you pretty much forgot they were there. At certain times, for instance, in summer in mid afternoon, the lines would begin to crackle and make buzzing/low tone arching type noises. Later in the afternoon the noise level increased and the lines would begin to slowly sway back and forth even though no wind was blowing. I am not sure if we imagined it or not, but it seemed like we detected a sensation like the hair standing up on your arms, head etc., during the time that the noise level was the highest and there was noticeable swaying of the lines.
We worked around and under those lines only a few hours each haying season and as far as I know, just like KOUA I am not aware of any detrimental affects from the exposure to the hight voltage transmission lines.
I never did get concerned about it, but my exposure was very minor and in those days you tended to assume the people in charge of things like power lines would be sure to prevent any harm coming to their neighbors. As time has gone on, that may have been proven a poor assumption.
To button this thing up, I also would recommend a thorough research of the most recent understanding of the affects of high voltage on you, especially if you are potentially putting yourself in a situation involving long term exposure to high voltage electric transmission lines and facilities.
The best of luck with your new property and heres hoping the transmission lines are much more a positive factor in the acquisition of and utilization of the property, especially when the lines might help keep the purchase price down and you would still have a great property to enjoy for many years.
Nick, North West Farmer
   / High Tension power lines #38
James K0UA
So ... a freak. :)
larry
   / High Tension power lines #39
So ... a freak. :)
larry
Just because I have 3 eyes, in each of my 2 heads I don't see why you should be calling me a freak.;)
The 69000 volt lines were probably 250 foot from the house. I never really noticed them much.
James K0UA
   / High Tension power lines #40
That one is really high potential. The main intertie has been a million volts since the '70s, and can handle a large portion of the energy output of the mighty Columbia. I can't imagine how many million horsepower was running down those wires. It's no wonder they crawled around a bit under heavy load.
2018 E-Z Beever M12R Towable Brush Chipper (A51691)
2018 E-Z Beever...
2012 Trail-Eze TE801 48ft 50 Ton Slide-Axle T/A Tilt Trailer (A51691)
2012 Trail-Eze...
BOMAG BW145D-40 SMOOTH DRUM ROLLER (A51246)
BOMAG BW145D-40...
MAJOR LOT NUMBER 260 (A53084)
MAJOR LOT NUMBER...
2019 KENWORTH T680 TANDEM AXLE SLEEPER (A53426)
2019 KENWORTH T680...
Tandem Axle Rear Truck Frame (A51692)
Tandem Axle Rear...
