19-23 Parker Hydraulic Control Valve
   / 19-23 Parker Hydraulic Control Valve #1
surreynd58785
1952 Ford 8N
Good evening,
I have a 19-23 Dearborn loader to which I am having issues with the hydraulic control valve and was wondering if anybody knows where online I can download the manual for it. It is a Parker 8743 control valve. Also, if I want to replace it with a much newer valve, what is out there that I can use? Any and all assistance would be greatly appreciated. Take care and God Bless.
Paul
(701) 728-6824
   / 19-23 Parker Hydraulic Control Valve #2
Is your system an open center hyd system?
How many GPM's does the tractor hyd pump produce?
Good question and I do not have an answer for you at this time. It originally came with the loader I was told. Any way of finding this out by looking at the pump? Thanks for the reply and have a great week.
Paul
   / 19-23 Parker Hydraulic Control Valve #4
Paul
The tractor specs say you have this for your Ford 8N.
Pressure: 1700 psi
Pump flow: 2.85 GPM
Not a lot of pressure.
Have you considered a PTO hyd pump to power the loader. More pressure and GPM.
11.4 GPM @ 2,000 PSI & 18.1 Hp input
Surplus Center - 5.7 CU IN PRINCE HC-PTO-2A PTO PUMP 540 RPM
   / 19-23 Parker Hydraulic Control Valve #5
Good evening,
Paul
(701) 728-6824
If you need a new loader valve, take a look at this one.
Surplus Center - 2 SPOOL 10 GPM PRINCE LVT1GB5AC1-26 OC VALVE
2020 Kinze 3505 High Speed 6/11 Planter (A56436)
2020 Kinze 3505...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
CATERPILLAR 255 SKID STEER (A52709)
CATERPILLAR 255...
2019 International DuraStar 4300 24FT Box Truck (A56858)
2019 International...
TEREX TH636C TELESCOPIC FORKLIFT (A52709)
TEREX TH636C...
SET OF PALADIN JRB 60" PALLET FORKS (A52707)
SET OF PALADIN JRB...
