19-23 Parker Hydraulic Control Valve
   / 19-23 Parker Hydraulic Control Valve #1
surreynd58785
1952 Ford 8N
Good evening,
I have a 19-23 Dearborn loader to which I am having issues with the hydraulic control valve and was wondering if anybody knows where online I can download the manual for it. It is a Parker 8743 control valve. Also, if I want to replace it with a much newer valve, what is out there that I can use? Any and all assistance would be greatly appreciated. Take care and God Bless.
Paul
(701) 728-6824
   / 19-23 Parker Hydraulic Control Valve #2
Is your system an open center hyd system?
How many GPM's does the tractor hyd pump produce?
Good question and I do not have an answer for you at this time. It originally came with the loader I was told. Any way of finding this out by looking at the pump? Thanks for the reply and have a great week.
Paul
   / 19-23 Parker Hydraulic Control Valve #4
Paul
The tractor specs say you have this for your Ford 8N.
Pressure: 1700 psi
Pump flow: 2.85 GPM
Not a lot of pressure.
Have you considered a PTO hyd pump to power the loader. More pressure and GPM.
11.4 GPM @ 2,000 PSI & 18.1 Hp input
Surplus Center - 5.7 CU IN PRINCE HC-PTO-2A PTO PUMP 540 RPM
   / 19-23 Parker Hydraulic Control Valve #5
Good evening,
Paul
(701) 728-6824
If you need a new loader valve, take a look at this one.
Surplus Center - 2 SPOOL 10 GPM PRINCE LVT1GB5AC1-26 OC VALVE
2013 Ford F-150 4x4 Crew Cab Pickup Truck (A55973)
2013 Ford F-150...
2015 Ford F-150 4x4 Crew Cab Pickup Truck (A56858)
2015 Ford F-150...
Enclosed Service Truck (A55788)
Enclosed Service...
HUSQVARNA RIDING MOWER 46IN DECK (A56859)
HUSQVARNA RIDING...
2020 John Deere 5065E 4 x 4 Tractor, S/N 1P45065EPLK406145, John Deere Diesel Engine, Cab, 3 Point (A59076)
2020 John Deere...
RAKE ATTACHMENT FOR MINI EXCAVATOR (A58216)
RAKE ATTACHMENT...
