why shouldn't I do this to the 3PTH? geometry?
   / why shouldn't I do this to the 3PTH? geometry? #21
On the lift arms imagine a line from your new "eyes" to the ball mounting point on the tractor. This is your new lift arm. Lengthening your lift links to bring the new eyes/new arms to their original position will cause virtually identical characteristics to the original. Forces consolidated in the composite lift arm/QA will be different but not felt much by tractor hydraulics owing to the small change in angle. The sweet/ strong spot in your lift range will change a little. Loss of the outer ball articulation will cause some binding if you tilt implement. Moving your top link point will be the same as if the lower links are stock. --Lower link point reduces lift capacity some but kicks the implement tail up quickly as you raise.
larry
Spot on.:thumbsup:
John Deere 568 Mega Wide Plus (A60462)
John Deere 568...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2003 IC Corporation 3000IC School Bus (A59230)
2003 IC...
2013 Dodge Charger Sedan (A55973)
2013 Dodge Charger...
2020 CATERPILLAR 306 CR EXCAVATOR (A60429)
2020 CATERPILLAR...
2024 Timpte 40ft Hopper (A56438)
2024 Timpte 40ft...
