why shouldn't I do this to the 3PTH? geometry?
   / why shouldn't I do this to the 3PTH? geometry? #21
On the lift arms imagine a line from your new "eyes" to the ball mounting point on the tractor. This is your new lift arm. Lengthening your lift links to bring the new eyes/new arms to their original position will cause virtually identical characteristics to the original. Forces consolidated in the composite lift arm/QA will be different but not felt much by tractor hydraulics owing to the small change in angle. The sweet/ strong spot in your lift range will change a little. Loss of the outer ball articulation will cause some binding if you tilt implement. Moving your top link point will be the same as if the lower links are stock. --Lower link point reduces lift capacity some but kicks the implement tail up quickly as you raise.
larry
Spot on.:thumbsup:
SHOPMADE MANIFOLD TRAILER (A58214)
SHOPMADE MANIFOLD...
2016 Kubota SVL75-2 (A53317)
2016 Kubota...
2024 CATERPILLAR 259D3 SKID STEER (A60429)
2024 CATERPILLAR...
2007 FORD F-150 XL TRITON (A58214)
2007 FORD F-150 XL...
2012 John Deere 6170R (A57148)
2012 John Deere...
1992 DFI PULL SPREADER (A57192)
1992 DFI PULL...
