Leinbach Land Plane & EverythingAttachments.com
   / Leinbach Land Plane & EverythingAttachments.com #11
I have been using back blades and b ox blades for about 20 years to maintain about a mile and a half of family gravel roads. I borrowed a Leinbach Land Plane with n o great expectations. Within about 10 minutes I knew I hjad to have one. I bought a Land pride 6' because I could not find a Leinbach dealer near me and I have been very happy with my landpride mowers. I see no difference between the 2. It works great. If you are maintaining a gravel road you will find they are idiot proof. Just drop it and drag.
Exactly :thumbsup:
They are almost too easy. You will love it.
Exactly :thumbsup:
I have not used it for anything else. Does anyone know how they work on a yard?
Mine worked great for grading the terrain along a fenceline I replaced. I removed the old, rusty 4-barbed wire cattle fence, land planed the entire stretch to smooth out the highs & lows & just make it flow better. Worked great. It had to drag through all kinds of crud, grass, weeds, vines, sticker, saplings, etc. Just keep driving back & forth from one end to the other, & the next thing you know it's smooth & ready for new fence.
My 6' Land Pride grading scraper is heavy enough to rip grass out without the teeth down, although may take a couple 2 or 3 more passes in some cases. Sometimes the ripped out grass will bunch up on the blade causing the blade to just slide over any other grass rather than ripping it out, so I'll lift the scraper to let the ripped-out grass fall off the blade, & then push (also using the scraper) that loose grass backwards out of the way. Works great.
   / Leinbach Land Plane & EverythingAttachments.com #12
Thank you bep
I am going to hit my slightly sinking drainfield with mine and see if I can straighten it out.
   / Leinbach Land Plane & EverythingAttachments.com #13
I can't think of hearing of even one person that has one of these that has ever had even one complaint about them.
You haven't talked to the right person.:D I hate mine. :smiley_aafz:
It seems like every time I hook mine up to do my driveway, someone in the neighborhood wants me to do there driveway. Or I get someone to show up from a client that I've done in the past. First thing out of there mouth is: so and so said you smooth drives real cheap. My response: the only thing cheap is my advise to you. "NOT FOR HIRE NO MORE, SO LEAVE !!!"
I think my neighbors watch my place and as soon I hook mine up, they call there friends and family and tell them to get over here if you want your drive smoothed right now cause he's got it hook up and he probably wont say no (wrong answer). :laughing:
I'm just tired of people wanting my service and not wanting to pay for it.
Now, for my own personal use, its the best implement that I own. :cool2:
   / Leinbach Land Plane & EverythingAttachments.com #14
Few pictures of mine when I built it.
   / Leinbach Land Plane & EverythingAttachments.com #15
Steve, your yard in the picture is very park like. :thumbsup: :thumbsup: How long does it take to mow the lawn? It sure is pretty there, you have quite a view. :cool:
   / Leinbach Land Plane & EverythingAttachments.com #16
Let's see. You could either raise your rates; Print up a nice looking page with your info, "services" & "rates", keep a few on your tractor, & just hand it to them ... or grade late in the afternoon or evening & respond with: "Sorry, it's too late. I only have enough daylight to do mine. And after this I've got to remove the grader to move onto _________ (fill in the blank: plow, auger, whatever)" :)
   / Leinbach Land Plane & EverythingAttachments.com #17
First off --EXCELLENT job of building that equipment. You should be proud of that.
When you dealt with the lawn did you have to plow or tear it up first or did you just go over and over the earth with your land plane?
Thanks for the compliment on the implements.:)
In the third picture the Deere 673 tiller was used to till everything up, ran it once over the entire area then raked up the debris, then ran the plane across it until smooth. I used a broadcast spin spreader for the seed and covered with the harrow in the last pic. Last trip was with a roller behind my small riding mower.
   / Leinbach Land Plane & EverythingAttachments.com #18
Thanks Brian, making it "park like" was my intention, glad it is percieved that way. This rear section sat for many years with brush, juniper trees and knarly bent over pine trees and a few piles of old farm trash. When I started to clean this up lots of the neighbors wanted to know what I was going to do with it, I told them I was going to put in a trailer park.:laughing: Had them worried for a while.
To mow the whole thing takes 2.5 hours with the L130 or about 1 hr with the x749.
Yeowzers!! that is one nice looking area jenkinsph! Makes me want to set up the crocuet set ASAP!!!
The home made land planes look FANTASTIC!! I wish I had the time (and/or the ability) to make one! Great work on thoes guys!
I think I'll have to paint mine to match my tractor .. that counts as a modification dosent it? ... hehehehe
Tractor on
   / Leinbach Land Plane & EverythingAttachments.com #20
I haven't played Croquet in almost 50 years, used to do this at my grandmothers when trying to grow up.:D
Thanks for the compliments, building the landplane and harrow were easy projects compared to some I have seen on here.
New/Unused 10ft 40 Drawer Workbench (A51573)
New/Unused 10ft 40...
Ingersoll Rand Air Compressor (A51573)
Ingersoll Rand Air...
2022 New Holland T5.120 Tractor with Loader (A51573)
2022 New Holland...
2016 JOHN DEERE 135G (A52472)
2016 JOHN DEERE...
2020 Polaris Ranger 1000 4x4 Utility Cart (A51694)
2020 Polaris...
2011 DODGE RAM 2500 (A52472)
2011 DODGE RAM...
