Will 3% gasoline in my diesel fuel cause problems?
   / Will 3% gasoline in my diesel fuel cause problems?
Its been a while but I think my Dodge Cummins diesel owners manual said a 10% mix of gas to diesel wouldn't hurt anything. Don't feel bad. I haven't used my chain saw for a couple of years and I filled it with gas with no 2 cycle oil today. Brain engaged just a couple of seconds before I started it.
Over here they call it "a senior's moment"
   / Will 3% gasoline in my diesel fuel cause problems? #12
My wife is less gentle. She calls it "stupid". I will be glad when I get to the "senior moment" stage of my life.The word "stupid" needs a rest.
   / Will 3% gasoline in my diesel fuel cause problems? #13
One of my guys was in Europe where most of the cars are diesel and grabbed the unleaded nozzle by mistake. He put a couple liters in the diesel tank before he realized his mistake. Hey, it was only a rental car, so he paid for the 2 liters, then filled the remainder of the tank with diesel. No problems showed up - he had the rental for an additional 2 weeks and did a lot of driving.
   / Will 3% gasoline in my diesel fuel cause problems? #14
in the old days.. be for fuel tank heaters , us long haul truckers would putt 5 gallons of gas in each tank . to keep fuel from gelling.. and alcolhol in the air lines.
and transmission fluid in the steering box.
kept you moving.
peabody
   / Will 3% gasoline in my diesel fuel cause problems? #15
heck, anti freeze used to be alcohol based.. (methanol ).
soundguy
   / Will 3% gasoline in my diesel fuel cause problems? #17
I worked for a major truck stop company, and mistakes happened here and there. A driver would cut loose a transport load of gas into the diesel tanks once in awhile in some state. They might fire you for that, but would not pump out the tanks if the total mix was 5% or less of gas.
   / Will 3% gasoline in my diesel fuel cause problems? #18
VW used to require something like 5-10% gas in the winter for its diesels. New ones don't need it though.
   / Will 3% gasoline in my diesel fuel cause problems? #19
Yep. BIG safety issue with putting gasoline in diesel. The fuel space in gasoline tanks is too rich to combust. The fuel space in diesel tanks is way too lean. Put gasoline in the diesel, and you'll have a nice combustible gas space in the tank. A bomb waiting for a spark.
Use kerosene if you want to winterize the fuel, 30-50%, or a diesel fuel additive.
Ralph
   / Will 3% gasoline in my diesel fuel cause problems? #20
Ralph
:thumbsup:Interesting point. Hadnt thot of that.
larry
3500# TANDEM BRAKE AXLES (A51248)
3500# TANDEM BRAKE...
2007 Ford Ranger Pickup Truck (A51692)
2007 Ford Ranger...
2015 Chevrolet Silverado 1500 Pickup Truck 4X4 (A53473)
2015 Chevrolet...
(INOP) VOLVO L70H WHEEL LOADER (A51243)
(INOP) VOLVO L70H...
43030 (A51691)
43030 (A51691)
LANESHARK LS3 LOT IDENTIFIER 103 (A53084)
LANESHARK LS3 LOT...
