Everlast Welders - Welders and Plasma Cutters by Everlast
   / Everlast Welders - Welders and Plasma Cutters by Everlast #221
Technically it should work. I think Mark said the PA200 puts out 70-OCVs. The LN-25 can accept 72-OCVs. You'd have to run the LN-25 on the VV mode, and you'd be stuck with fluxcore wires only. Personally I wouldn't do it, but if I had to I wouldn't use anything bigger than .045 wire. The reason I say I wouldn't do it, is because I have better machines suited for wire feed work.
Maybe Mark can help here if I missed something.
   / Everlast Welders - Welders and Plasma Cutters by Everlast #222
deereman75 I was wrong about the LN-25 accepting 72-OCVs.:eek: Thats what latest version of the old LN-22 could take, the LN-25s can take up to 110-OCVs.
   / Everlast Welders - Welders and Plasma Cutters by Everlast #223
Ok I probably never will do that, I was just wondering if you had done it. Now that I think about it, how much do used ln 25s run?
   / Everlast Welders - Welders and Plasma Cutters by Everlast #224
Oh wow, that's a hard question to answer! Too many variables.
I've seen just the bare feeder go in the low 200s, but that doesn't mean they even worked, or worked well.
I paid $750.00 FOB my front porch for a gray model, with 3-guns. 2-Mig guns, and a Lincoln K-126 Innershield gun. Complete set of drives rolls, and guide tubes. And a set of pie pans for the 14-pound rolls of Innershield.
If you buy one try to buy the gray model, or the very early black model. Remember they don't all come with a contactor kit, or gas solenoid kit, so be careful!;)
   / Everlast Welders - Welders and Plasma Cutters by Everlast #225
Hmm it seems ebay isnt the best place to look. I am seeing black ones without a gun going for $700+...
   / Everlast Welders - Welders and Plasma Cutters by Everlast #226
Ok maby ebay isnt so bad. I just saw a gray one with 2 guns on kijiji for $3000....
   / Everlast Welders - Welders and Plasma Cutters by Everlast #227
Yeah, pricing on LN-25s are all over the place! Some people are just nuts with their asking price.
Put Lincoln LN-25 into your saved searches on ebay, that way you'll get an e-mail every time an LN-25 is listed.
   / Everlast Welders - Welders and Plasma Cutters by Everlast #228
Mark, I am looking to add a stick welder and plasma cutter to my work shop for my upcoming loader/backhoe project and I have a couple questions. I am also pretty new to sticking metal together so ease of use and my shop is small (17wx28L) so space is an issue that's why I am interested in the 3 in 1 unit's as well as the portability of them. I am on a limited budget as well; I just want to make sure this unit is going to do everything I need it to do for quite a while before I spend any money.
1. I am looking at the MultiPro205 and I don't see max thickness listed of the material that it can weld in a single pass?
2. Is there a PDF manual for them somewhere that I can download and read? I looked on the web site but didn't see one.
3. What are the advantages/disadvantages of DC welding over AC and vice versa?
I don't recommend any combination plasma/tig/stick units. Too much going on inside. Not our best product.
Do you mean powerultra or powerpro? I don't sell them if I can help it.
If you want a stick and a plasma cutter, I can make you a price on it, if you call me.
   / Everlast Welders - Welders and Plasma Cutters by Everlast #230
Agree with Mark about the multi-units. It is refreshing to see his comment since he sells them, too. Really an up-front evaluation.
I went with the separate units, PowerArc 200 and the PowerPlasma 70, and couldn't be happier. With the heavy metal and cutting needed to be done on a backhoe it would be best to buy something a bit bigger than "necessary". As us tractor folks know, you never have too much power.
With a little bargaining you may be able to get the separate units for less than a multi. And the inverters are so small that they take up very little space.
UNUSED WOLVERINE QUICK ATTACH MOUNTING PLATE (A51248)
UNUSED WOLVERINE...
UNUSED CFG QK18R EXCAVATOR (A51247)
UNUSED CFG QK18R...
2023 JOHN DEERE 8R370 LOT NUMBER 204 (A53084)
2023 JOHN DEERE...
2008 DOOSAN G25 GENERATOR (A52472)
2008 DOOSAN G25...
2025 JMR Tree Boom Skid Steer Attachment (A51691)
2025 JMR Tree Boom...
2013 Volkswagen Passat Sedan (A51694)
2013 Volkswagen...
