what year is my DADS 2000 ford tractor
   / what year is my DADS 2000 ford tractor #1
farmerfloyes
ford 2000,model B1012B
[Hello, I just accquired my dads ford 2000 tractor. Im gonna fix a few things and give it back to him. i have numbers from all over the tractor but still dont know what year.tractor #C296472,model B1012B, number stamped on trans housing C7 NN 7006 AK, motor number C 9 NN9425E, would really appreciate any information, thanks.god bless
   / what year is my DADS 2000 ford tractor #2
C296472 is the serial #. The C indicates USA as country of origin. And the serial # puts it at a 1971.
The B1012B is your actual model code.
B= model 2000
10= Agricultural All purpose
1=diesel
2=transmission driven 540 PTO
B=transmission code, but a "B" isnt showing up.
Here are a couple of good sites
TractorData.com Ford 2000 tractor information
FORD CODES and SERIAL NUMBERS
There should also be another code or # there by the starter where you found those two. It will give an actual build date down to the day and even what shift of the day:thumbsup:
Good luck with it.
:thumbsup: I REALLY APPRECIATE IT....I SEE ALREADY THIS CITE IS GOING TO BE A VERY HELPFUL..THANKS AGAIN
GONNA CHANGE OUT DIESEL FUEL INJECTOR PUMP, ANY ADVICE ON WHERE TO FIND CAV INJECTOR PUMP TIMING SETTINGS
   / what year is my DADS 2000 ford tractor #5
I got nothing on that one.
Soundguy probabally knows. He will probabally be around if he hasnt already responded in your duplicate thread.
thanks, didnt know i duplicate thread...computers
   / what year is my DADS 2000 ford tractor #8
B tranny code should be a twin stick 6spd IIRC
   / what year is my DADS 2000 ford tractor #9
I am also looking for some info/help.. I have just recently purchased a ford 2000 .. I have 2 numbers but it just doesn't seem to add up.. the numbers are:
6M7B
21022A
C158881 6MB
as I read this it is a 2000, but where it gets confusing is that mine has a diesel engine.. but that number indicates a gas engine..any and all help/information is greatly appreciated.
Travis
   / what year is my DADS 2000 ford tractor #10
Can you upload a picture of the ID plate?
I'm not getting consistent results from the vin sites I've checked.
   / what year is my DADS 2000 ford tractor #11
50 year old tractor. Could have easily had an engine Swap
   / what year is my DADS 2000 ford tractor #12
Point.
   / what year is my DADS 2000 ford tractor #13
6M7B
21022A
C158881 6MB
Travis
I'm not sure what / where you are getting your bad info.. Maybee it's because you are thinking it is a VIN code.. ford tractors don't have VIN codes.
the have model ID numbers, serial numbers, and date codes. and you have all 3, and they are VERY easy to decipher
21022A This is a model ID.
2 = 1965- 3/1968 ford 2000
10 = Ag chassie
2 = gas engine
2 = trans 540 pto
A = 4 speed
As was said.. engines get changed.. and so do transmissions... could have been a trans swap.. or engine..
C158881 is a serial number. It puts it as a late 66 model. 1966 SN range started with C124200, 1967 SN range started with C161300
6M7B is a date code. 6 = 1966 M = December 7 = day of month B = B / DAY shift Dec, 7, 1966 which goes along with late 66 sn.
   / what year is my DADS 2000 ford tractor #14
I thank you all for the information, I hope to use this site for quite a bit of changes that I am wanting to do to my tractor.. not particularly fond of the transmission PTO, but it is what it is.. I will just have to adjust to using it.
Travis
   / what year is my DADS 2000 ford tractor #15
Unless you are running a hay bailer, it isn't much of an issue to overcome the limitations of a non live pro. Just remember to use an orc if running a high inertia implement, like a rotary brush mower.
2018 Chevrolet Tahoe SUV (A59231)
2018 Chevrolet...
2016 Ford F-150 Pickup Truck (A59230)
2016 Ford F-150...
Toro Zero Turn Lawn Mower (A56859)
Toro Zero Turn...
WOOD GRABBER FOR MINI EXCAVATOR (A58214)
WOOD GRABBER FOR...
MARATHON 20KW GENERATOR (A58214)
MARATHON 20KW...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
