JD 2320 with MMM
   / JD 2320 with MMM #1
jcdogfish
Louisiana
Mahindra 2516
Is there anything left hanging down after the deck is removed?? I'm looking hard at this tractor and trying to decide on a MMM or finishing mower. Thanks
   / JD 2320 with MMM #2
Does it have the independent lift on it?
I believe when the mower is completely removed there is nothing to hang down(that is how mine is w/o the mower, I have a RFM). Now if you leave the linkage on the tractor it might hang down some but it shouldn't be too bad with it locked up.
   / JD 2320 with MMM #3
With the independent lift kit, the lift arms are still on the tractor, but when locked up they don't hang down enough to be of any concern. I assume it's similar without the independent lift kit, but I never really looked close at one.
   / JD 2320 with MMM #4
Not sure if it is in your money cards, but step up to the 2520 if you can. It has twice the hydraulic power, a better alternator, bigger tires, and a few other things I don't remember.
   / JD 2320 with MMM #5
no the arms move and are out of the way. then move the height dial up locks them up so you can use the 3 point hitch. but if you can get a 2520 there is alot of upgrades that are big if your into proformance. 2 hydraulic pumps. one for steering & the other for the hydraulics. i had a 2320 for a year. but needed more power so i got the 2720 its everything i need. snowblow 52",mow62",loader work,tilling with no bog downs.
2016 INTERNATIONAL 4300 26FT BOX TRUCK (A54607)
2016 INTERNATIONAL...
Toro Workman MDX Utility Cart (A51694)
Toro Workman MDX...
UNUSED Grey Waterproof PE Tarpaulin w/Grommets (A53117)
UNUSED Grey...
2008 DRAGON 150 BBL ALUMINUM VACUUM TRAILER (A53843)
2008 DRAGON 150...
