How do you transport your tractor & batwing bush hog?
   / How do you transport your tractor & batwing bush hog? #151
BELIEVE ME....if I could I would. I couldn't find a 5500 4x4 with the packages I needed nearly as cheap as the Ford.
Hopefully after this t-stat gets changed and the other things I've done, it'll be more reliable.
My 7.3powerjoke is still in the shop,so I went and bought me a new cummins...
Glad u have warrenty!!!
UPDATE: Just got phone with Ford service. As I posted previously, truck needs a thermostat and upper rad hose. Good news is the T-stat is covered, rad hose is not, but is only $35.
But there's bad news, too: Low pressure fuel pump took a dump. Not covered under warranty $469. Ouch.
I think I got me a lemon.
   / How do you transport your tractor & batwing bush hog? #153
a thermostat coded? was it stuck open and running cool or something?
   / How do you transport your tractor & batwing bush hog? #154
sorry about that/. figured there had to be more than a thermostat causing a power drop.
soundguy
   / How do you transport your tractor & batwing bush hog? #155
carefull.. that sounds a bit like brand bashing :)
different forum.. but.. :)
BRAND BASHING
We ask that anyone posting in the Trailers & Transportation forums refrain from brand bashing with terms such as Durajunk, Powerchoke, etc... It is not acceptable in the tractor brand forums and, as such, is not acceptable here, either. Thank you.
__________________
http://www.tractorbynet.com/forums/trailers-transportation/153558-brand-bashing.html
don't worry.. I don't like gm stuff.. so it all works out in the end.. :) :)
I'm beginning to realize I have a 6.4L "powerjoke". LOL
:laughing:
Is it against the sacred "rules" to make fun of your own truck? I know it is OK to slander dealers publicly, publish their phone numbers and make racial remarks about their employees, so it must be OK to make fun of my own truck!!! Heck, I've been slandered by other members here, so I better be able to slander my own truck.
   / How do you transport your tractor & batwing bush hog? #157
Yeah,I figure if its mine I can talk about it.Not everything is going to be positive.I did buy the truck used,so cant really say much.Dont know how the owner before me took care of it. It will cost me around 5grand when everything is done,but I will keep her around.
OMG, 5 grand. :confused2:
I was upset cause mines gonna be $800+. :(
UNVERFERTH 330 - 22-INCH EXTENTSION TUBE FOR BASE AND WING ASSEMBLY FOR RIPPER (A55301)
UNVERFERTH 330 -...
20X30 ALL STEEL CARPORT (A53843)
20X30 ALL STEEL...
JOHN DEERE 1700 LOT NUMBER 17 (A53084)
JOHN DEERE 1700...
2004 MACK GRANITE CV713 DUMP TRUCK (A51406)
2004 MACK GRANITE...
Two Pairs of 8ft Fork Extensions (A53421)
Two Pairs of 8ft...
TAKEUCHI TB250-2 EXCAVATOR (A52705)
TAKEUCHI TB250-2...
