jake98
- Joined
- Nov 10, 2007
- Messages
- 1,824
- Location
- Dingmans Ferry PA
- Tractor
- 53 Cub, 70's JD 410, Kioti 25hst
Jake, let us know how you like it and if you think that the restrictor makes the control manageable. The first question that I usually get is why doesn't the hydraulic work right? It always ends up that the customer hasn't fully cycled the unit enough times to get the air out. I recommend 10-20 full cycles and you are usually good to go. I suppose that I ought to start putting a flyer in the box suggesting to cycle the hydraulic several times.
Hi Brian - putting a restrictor in the tilt now to slow the speed? I have been thinking of adding a pilot operated check on mine because apparently my Kubota remote valve is leaky so it drifts down, and is load sensitive. Plowing put the highest load on the tilt so I uncoupled the hoses but that defeated the purpose. It's so nice to be able to tweak from the seat. Have you got any good suggestions for a check? I found a Prince model RD1450 that looks like it is just what I need but when I saw this thread I thought I would check with you before buying one. Thanks
