Grapple Grapple research and tentative conclusion what may be best for me; what do YOU think?
   / Grapple research and tentative conclusion what may be best for me; what do YOU think? #131
Connie from Wildcat called me last night. They are going to ship me some shims to have welded on. :thumbsup:
Sounds like that's the same thing I'll be getting.
   / Grapple research and tentative conclusion what may be best for me; what do YOU think? #132
Finaly got it scheduled for next week! I'm having the WR Long system installed. Can't wait to try out my new grapple!
   / Grapple research and tentative conclusion what may be best for me; what do YOU think? #133
More important than the gap is how far the retaining pins protrude below the mount when locked. If they are lower than the gap distance it is pretty hard to dismount the grapple accidently.
If there is almost no gap then mounting the grapple can be a bit tricky as it might not move all the way flush unless you lift it and tilt it backwards. That is a hassle and presents its own problems in reaching the locking lever safely etc.
Bottom line is that some gap is desirable and I'd imagine a minimum of 1/4 inch or so. Again, the key issue is how far the retaining pins protrude from under the mount when locked.
The 1/4" or so gap I found (after reading this thread) between the retaining pin and mount on mt 48" WildKat grapple certainly explains the "grapple flap" I have when crossing a bumpy field. Even though the pin extends well below the hole and falling off is not a problem, I'm considering a shim to reduce the gap. Need to check the stock bucket if I ever put it back on as it too will flap under the same circumstances.
   / Grapple research and tentative conclusion what may be best for me; what do YOU think? #134
Grapple flap, I love it!
Jim
   / Grapple research and tentative conclusion what may be best for me; what do YOU think? #135
Received mine today. Rather than "shims", they sent me another set of the exact same piece that Wild Kat uses for the pin securing mount tabs. I had a local welder cut those into rectangular pieces & weld them on to take up the ~7/16" gap I had with mine. Now the pins fit very tight & the play is eliminated.
   / Grapple research and tentative conclusion what may be best for me; what do YOU think? #136
Bep - That is exactly what they mean by shims - and exactly what you need.
   / Grapple research and tentative conclusion what may be best for me; what do YOU think? #137
Received mine today. Rather than "shims", they sent me another set of the exact same piece that Wild Kat uses for the pin securing mount tabs. I had a local welder cut those into rectangular pieces & weld them to that take up the ~7/16" gap I had with mine. Now the pins fit very tight & they play is eliminated.
Bep how long did it take the welder to make this repair/modification?
James K0UA
   / Grapple research and tentative conclusion what may be best for me; what do YOU think? #138
James K0UA
10 minutes of actual work, ~35 other minutes of shootin' the breeze :)
   / Grapple research and tentative conclusion what may be best for me; what do YOU think? #139
Could you post a pic when you get a chance? I'm having trouble visualizing the fix....
   / Grapple research and tentative conclusion what may be best for me; what do YOU think? #140
Sure, meantime here's a sketch of it:
attachment.php
500BBL WHEELED...
2007 Sterling L7500 Terex Commander C6060 60ft Insulated Derrick Digger Truck (A55973)
2007 Sterling...
2017 Mercedes Benz GLA SUV (A56859)
2017 Mercedes Benz...
2016 Komatsu WA380-8 Wheel Loader, S/N 15080, PIN# KMTWA13OCGA015080, Turbo Diesel Engine, Komatsu (A59076)
2016 Komatsu...
2008 WABASH 53FT REEFER TRAILER (A58017)
2008 WABASH 53FT...
2021 Ver-Mac PCMS-3812 Solar S/A Towable Trailer Message Board (A55973)
2021 Ver-Mac...
