CK35 Hard Starting lots of white smoke
   / CK35 Hard Starting lots of white smoke #1
raypope
Member
Kioti CK35HST 2008'
I have a 2008 CK35 HST with 400 hours.
This has been a great machine, but recently it has been increasingly hard to start. Temperature is in the 30s at night and around 50 when trying to start. Turning the key and allowing the glow plug to cycle only turns the engine over with whitish grey smoke and the smell of diesel from the exhaust. There is the loud click of a solenoid engaging each time the key is turned to the preheat position.
I've used this unit a 0 degress F and it would crank the first time every time.
I have plenty of fuel, with cold weather additive and Lucas fuel additive. Battery is good key-switch is good fuses are good. No water in fuel, fuel and air filters are clean.
Any ideas?? :confused:
Ray...
   / CK35 Hard Starting lots of white smoke #2
I would check to see if your glow plugs or intake heater is actually working.
   / CK35 Hard Starting lots of white smoke #3
x2
Sounds like you are getting no power to your glow plugs.
Update:
Found the issue.
Key-switch was not providing enough contact to fully energize the glow plugs. Cleaned contacts on the tractor side connector added di-electric grease. The female side of the connector isn't replaced when installing a new keyswitch.
FYI.
2013 Ford E-150 Passenger Van (A59230)
2013 Ford E-150...
T/A Flatbed Trailer (A59231)
T/A Flatbed...
JOHN DEERE 410L BACKHOE (A52706)
JOHN DEERE 410L...
2020 Case 5550 Trident (A56438)
2020 Case 5550...
2023 FORD F-150 XL CREW CAB TRUCK (A59823)
2023 FORD F-150 XL...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
