Grapple Grapple research and tentative conclusion what may be best for me; what do YOU think?
   / Grapple research and tentative conclusion what may be best for me; what do YOU think? #141
   / Grapple research and tentative conclusion what may be best for me; what do YOU think? #142
Actually, that's probably better than a pic. Thanks -- looks like a have a new project....
We let this tab extend toward the securing pin's sloped surface by 7/16", & that did the trick.
   / Grapple research and tentative conclusion what may be best for me; what do YOU think? #143
We let this tab extend toward the securing by 7/16", & that did the trick.
That was exactly what I had in mind for the repair. Glad you got it solved.
James K0UA
   / Grapple research and tentative conclusion what may be best for me; what do YOU think? #144
Grapple flap, I love it!
Jim
Yeah, it didn't occur to me how that one would roll off the tongue.:laughing: BUT it really does describe the experience of hitting a bump and having the front of the grapple fly up and then come down with a loud CLANG. Every time I'd think "That can't be good for my hydraulics...."
I was thinking I might go a little long and then grind it back to a perfect fit.
   / Grapple research and tentative conclusion what may be best for me; what do YOU think? #145
Received mine today. Rather than "shims", they sent me another set of the exact same piece that Wild Kat uses for the pin securing mount tabs. I had a local welder cut those into rectangular pieces & weld them to that take up the ~7/16" gap I had with mine. Now the pins fit very tight & they play is eliminated.
Glad you got everything sorted out and fixed! :thumbsup:
   / Grapple research and tentative conclusion what may be best for me; what do YOU think? #146
I thought about that, too, but just decided to settle on 7/16" & see how that worked. And it does :thumbsup:
   / Grapple research and tentative conclusion what may be best for me; what do YOU think? #147
Here is the fix (click on them for bigger pics):
Unpainted:
Painted:
   / Grapple research and tentative conclusion what may be best for me; what do YOU think? #148
OK... I found some stats and did a few calculations. A 10' long 12" diameter log of softwood will contain roughly 7.855 cubic feet of material. The stats I found listed softwoods ranging between 22 and 43 lbs per cubic foot. This works out to between 172 and 337 lbs per log. I seriously doubt that I would be tackling more than two logs at a time. According to this, two logs would weigh a MAXIMUM of 674 lbs. 1,150 - 674 = 476 lbs for the grapple.
Those are dry wood weights. Most logs are wet. None are dry. You should count on the average being above 43#/cuft.
larry
   / Grapple research and tentative conclusion what may be best for me; what do YOU think? #149
larry
How do you know they are "dry weights?" Naturally I took that into account but the article I read was about various "trees" (not firewood or lumber). There was no mention of moisture content so I had to assume the article was about fresh cut trees. Do you have other information?
I suspect moisture content was the reason they gave a range of between 22 and 43. so it wouldn't change my conclusion regardless. I wanted to determine the maximum weight of softwood logs.
   / Grapple research and tentative conclusion what may be best for me; what do YOU think? #150
Good question.:) ... First off my impressional experience said otherwise. -- I did some raft building as a kid and found most forest wood to be not much lighter than water [62.4#]. I found nothing that "bobbed" on the water like I would consider a 1/3 density weight at 22# doing. Nothing even that floated half way up [31#]. Best I could judge the wood logs, various and unidentified, floated 1/4 or less out of the water. ... -- So yesterday I looked for wet and dry wood weights. I couldnt find wet, but I have an old Handbook of Chemistry and Physics that has a table of "Oven Dry" weights. These numbers match what you quoted. ...Neglecting cork and balsa of course! ;)
larry
Massey Ferguson 1759 (A57148)
Massey Ferguson...
New/Unused CFG Industrial MH12RX Mini Excavator (A57453)
New/Unused CFG...
LOT: (6) Office Chairs (A59076)
LOT: (6) Office...
2017 Elgin Broom Badger Sweeper, Kubota Turbo Diesel Engine, High Dump, Dual Tilted Gutter Brooms... (A59076)
2017 Elgin Broom...
2021 Ford F-150 4x4 Ext. Cab Pickup Truck (A54814)
2021 Ford F-150...
Heavy Duty Skid Steer Breaker (New/Unused)(Est. Retail Value $4,800). (A59225)
Heavy Duty Skid...
